Disable PATS for TS 6-Position Chip
Old May 9, 2014 | 12:38 PM
BeachEx's Avatar
BeachEx
I'm thinking I want the Phoenix chip but it disables the PATS, don't really care about the PATS if it only eliminates the "chipped" key. I only have one key for my Ex and don't want to pay $75 for a new one.
Will the "alarm" horns still work if door is opened with doors locked or is the whole system down?
Will keypad still unlock the doors?
Will remotes still unlock doors?
from KT Performance website
"If you are installing the chip in an Excursion with PATS factory anti theft system, this chip will disable the PATS system.
-To eliminate the "THEFT" light, you must disconnect the red connector from the PATS module.
-The PATS module is located below the dash directly above the transmission hump in the floor.
-With the PATS disabled, any key that turns the injection will start the engine. In other words, a non-chip key will start the vehicle."
Thanks
Josh
Old May 9, 2014 | 08:53 PM
Restlesswildman's Avatar
Restlesswildman
I am wondering why you want to pull the chip and replace it when you can get a SCT tuner and flash the stock PCM/ECM.
Old May 9, 2014 | 10:11 PM
BeachEx's Avatar
BeachEx
Not pulling a chip, haven't bought one yet. Just want to know about PATS... and sct is not switch on the fly don't want that
Old May 10, 2014 | 11:17 AM
Restlesswildman
I didn't know you could change the program on the fly.....
Old May 10, 2014 | 04:21 PM
BeachEx's Avatar
BeachEx
Yes, with the 6-position switch and the ones with the digital button switch which have 17 different tunes, and all you have to do is turn the dial or push the button to change between tunes at anytime.
Old May 13, 2014 | 12:19 PM
BeachEx's Avatar
BeachEx
Does anybody know the answer? or am I going to have to try it and find out.
Old May 19, 2014 | 08:00 AM
BeachEx's Avatar
BeachEx
Bump to top
Old May 19, 2014 | 08:40 AM
Kdr358's Avatar
Kdr358
I'm assuming you have a diesel but 7.3 0r 60?
Old May 19, 2014 | 12:17 PM
BeachEx's Avatar
BeachEx
Info in my Sig
It's a 2000 model so 7.3
Old May 19, 2014 | 12:35 PM
Kdr358's Avatar
Kdr358
I didn't catch it being on the phone app, have you tried posting in the 7.3 section? It might point you in a better direction
Old May 19, 2014 | 02:02 PM
EXv10's Avatar
EXv10
I wouldn't buy anything that disables the pats, you are just getting deeper into undependable territory.
Old May 20, 2014 | 05:46 PM
Misky6.0's Avatar
Misky6.0
Thanks
Josh
To my knowledge,
There is no alarm that triggers, other than the panic button on the remote.
The pats verifies the correct key is used, thus preventing a hot wired theft. It does NOT cause an "alarm" to go off.
Sent from my Sprint PC36100 using IB AutoGroup
Old May 20, 2014 | 05:55 PM
EXv10's Avatar
EXv10
Originally Posted by Misky6.0
To my knowledge,
Right, maybe just the horn beeping.
Old May 21, 2014 | 12:11 AM
Stewart_H's Avatar
Stewart_H
6.0's get reflashed because you can't use a switch on the fly chip with multiple tunes on it.
Most 7.3L owners opt for a chip with multiple tunes so they can switch from a daily tune to a tow tune to a whatever tune, with just a push of a button or twist of a dial.
Will the "alarm" horns still work if door is opened with doors locked or is the whole system down? YES
Will keypad still unlock the doors? YES
Will remotes still unlock doors? YES
The 7.3L F series trucks don't have PATS and all those functions work when custom tuned.
Stewart
Old May 21, 2014 | 05:29 AM
BeachEx's Avatar
BeachEx
Thank you Stewart, that is exactly the answer I'm looking for!
Seven-Point-Three
Sep 15, 2010 08:52 AM
John7894
Jan 4, 2009 07:52 PM
sturzinator
Sep 24, 2007 09:15 PM
mpdej8
1997 - 2003 F150
Jan 7, 2002 04:26 AM
