Died. Now no start
Old May 7, 2014 | 04:21 PM
Juicyjuice4x4's Avatar
Juicyjuice4x4
Died. Now no start
So on my last off roading trip, I was trailering my jeep back home. It's trailered one ton jeeps 300 miles round trip multiple times and this time I drove about 100 miles round trip. As I was pulling in front of my house after the trip, it died. I thought I had stalled out...even though I knew I hadn't. I've been having a hard time keeping the wire from the battery to the starter connected. Re-connected it and tried to start it again. Nothing...turns over non-stop. Thought maybe the battery was too low to start the truck, but I jumped it off and it still just turned over. It has a fresh oil change and fuel filter as well as a fresh tank of diesel and additive. Anyone have any ideas? I need the truck to start so I can move the trailer out of the way...thanks everyone
Old May 7, 2014 | 04:42 PM
Hussler's Avatar
Hussler
Got a wait-to-start light?
Old May 7, 2014 | 08:46 PM
fordpride's Avatar
fordpride
Do you have wts light ?
Any smoke from tail pipe ?
Does the tax move when cranking ?
Have you tried a CPS ?
Old May 7, 2014 | 09:09 PM
Juicyjuice4x4
Wts light comes on. No smoke. I have not tried CPS yet
Old May 7, 2014 | 10:43 PM
fordpride's Avatar
fordpride
Try a CPS
10 characters
Old May 12, 2014 | 11:50 AM
Juicyjuice4x4
Replaced camshaft sensor and both batteries and still nothing. Just sits and turns over without even trying to crank
Old May 12, 2014 | 12:30 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Lightbulb
Check the oil level in the HPOP reservoir.
Old May 12, 2014 | 12:35 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Wink
Read this :
Diesel Diagnostic information for Powerstroke 6.0, 7.3, IDI 7.3 and 6.9 L, by Oregon Fuel Injection
Old May 12, 2014 | 01:06 PM
Juicyjuice4x4
sorry if this is stupid...but how do i do that?
Old May 12, 2014 | 01:12 PM
oldbird1965's Avatar
oldbird1965
Its the reservoir on the front top center of the motor. Take the plug out on the right top and see the oil is about half inch from the top. If not, fill it with oil.
Old May 12, 2014 | 01:29 PM
Juicyjuice4x4
The HPOP is full and the oil looks brand new (considering it only has 100 miles on it...)
Old May 12, 2014 | 03:14 PM
tiopet's Avatar
tiopet
Water in the IDM gave my neighbour same problem.
Old May 12, 2014 | 03:56 PM
Pikachu's Avatar
Pikachu
Is the IPR still secure, with the spacer on and the nut tight? Checked your fuel pressure? Do you have any way to monitor the ICP, IPR duty cycle and injector pulse width while cranking? AE or Torque Pro perhaps? Probably won't make a difference, but you could try starting it with the ICP sensor disconnected and see if runs.
Old May 12, 2014 | 04:33 PM
Juicyjuice4x4
I'll check all of that when I get home and I will disconnect the icp sensor and see if that works. However, based on the no start/hard start chart in an above post, I may not have fuel...no smoke comes out of the exhaust. There's fuel in the bowl and the filter is brand new. I tried to get my gauge on, but I couldn't due to the engine hoist tabs
Old May 12, 2014 | 04:51 PM
Pikachu's Avatar
Pikachu
It may not be fuel pressure, but it's a good idea to check it first to rule it out. There are several parameters that have to be met before the PCM sends a fuel delivery command signal to the IDM. Minimum ICP 500 psi, minimum RPM 100, minimum voltage 7.0. When those parameters are met, the fuel injector pulse width should come up somewhere between 1.0 and 6.0 milliseconds to fire the injectors. Note: if you get an RPM reading on a scan tool while cranking, the CPS is working.
Unplugging the ICP sensor causes the PCM to use an inferred pressure table and makes the 500 psi minimum irrelevant. If you have good batteries, good fuel pressure, and disconnect the ICP sensor and the truck still won't start, it's more than likely high pressure oil related; IPR, HPOP, or leaking o-rings. Of those three, a bad HPOP is the least likely. IPR problem is most likely, but before I did anything I'd check the HPO pressure while cranking either with a known good ICP sensor and scan tool, or a 3,000 psi mechanical gauge.
