Starts fine, idles fine, drives fine for 30 to 45 minutes. Then, when stopped, begins to idle rough. Taking off produces popping through the carb. Then as car is driven popping continues intermittently.
Have replaced plugs, ditributer and rotor, fule filter, PCV valve, fuel pump. Car passed emmission test when taken in before the 30 to 45 minutes went by.
I posted this message under a few catagories. I'm new here, so if this isn't the right place, sorry.
I have a 1979 an i had the same problem as you,and i found out that the problem was that the timing needed reset,and that my carb needed rebuilt,so you might want to have that checked
