Backfires through carb
Old Jul 6, 2003 | 10:25 AM
Chuck Batt's Avatar
Chuck Batt
77 Ford van 351W
Starts fine, idles fine, drives fine for 30 to 45 minutes. Then, when stopped, begins to idle rough. Taking off produces popping through the carb. Then as car is driven popping continues intermittently.
Have replaced plugs, ditributer and rotor, fule filter, PCV valve, fuel pump. Car passed emmission test when taken in before the 30 to 45 minutes went by.
Old Jul 6, 2003 | 04:42 PM
RSRacing's Avatar
RSRacing
have you checked the timming maybe the vacum advance is too much i race a chev 350 and it usted to do that to me coming out of a corner downshifting and all it was was that my vacum advance was set wrong just an idea if it helps
Old Jul 7, 2003 | 01:29 PM
Chuck Batt's Avatar
Chuck Batt
Thanks RSR, I'll see if it makes a difference.
Old Jul 7, 2003 | 06:44 PM
RSRacing's Avatar
RSRacing
No proiblem man glad to help
Old Jul 7, 2003 | 08:24 PM
Caddy 53's Avatar
Caddy 53
Chuck Batt:
You might try a compression chk for leaking valves or one that warps etc. when hot. caddy 53 chuck
