Sponsored by: Real Truck
AC switching modes
Old May 6, 2014 | 07:43 PM
07Cruzer's Avatar
07Cruzer
AC switching modes
Hey everybody, 06 F250 gas King Ranch. My AC wants to switch modes on its on. I can have it on vents & it will go to defrost then back to vents every few minutes. Any clues? Air is cold.
Old May 6, 2014 | 09:51 PM
Mike189677's Avatar
Mike189677
Vacuum leak. Check the vacuum lines coming from the auto hubs up to the vac pump if you dont find cracks there start following the vac lines under the hood.
Old May 7, 2014 | 05:21 AM
redford's Avatar
redford
FTE Leadership Emeritus
The heating system uses vacuum to move things. When there is insufficient vacuum to drive the system, it reverts to blowing out the defrost vents.
Old May 7, 2014 | 12:43 PM
07Cruzer's Avatar
07Cruzer
You guys are exactly correct! I was at work when I posted the original message. So today I checked under the hood & sure enough the small vacuum line 1/8" OD maybe on the passenger side maybe was off. It's loose so I'll replace it. But the drive home it stayed in the vent selection.
Thanks again.
Ronnie
Old May 7, 2014 | 07:56 PM
Lubbockguy1979's Avatar
Lubbockguy1979
Ok next question.... how can I make the recirculate the default hvac action and fresh air by selection only on the digital climate control? I typically remember to switch it once behind a stinking vehicle or other foul odor
snorindad
Apr 23, 2023 10:46 AM
Dude-Ford
34
Jan 10, 2023 12:08 PM
oldcoupe42
Aug 14, 2016 07:39 AM
ScotF150
Modular V10 (6.8l)
Jul 20, 2011 09:04 PM
pat hand
Jul 14, 2004 09:25 PM
