frame swap, or what????
1. I've looked at the rears off the 72(?) truck as an option, but that would still leave me with no power anything and I would still have to change the gears for decent cruising speed.
2. The Ranger frame swap, off a mid 80's regular cab longbed. This would provide power steering, brakes, etc. But with two problems. first, I would have to get engine mounts for a 302 or 390 welded in, and second, Ive heard that it requires fabrication of some brackets for the body and running board mounts. If anybody has any experience with this, please let me know how hard it was, how long it took, and what tools you used.
3. This one is the touchy subject. A frame swap with a 78-79 Thunderbird. Some say EASY as pie and others say they wouldn't touch it with ten foot pole. Benefits are power everything, plus some of these came with 390's I beleive or at lest 302's, so the mounts would be readily available for either motor. If you have had any experience with this or can get me in touch with someone who does, please let me know. Thanks.
Thanks for all the interesting info on your restorations. I'm sure that A LOT of it will come in handy in the coming months. Thanks again.
Paul
1950 F-1
390 w/ a C-6
Overpowered and undergeared
Of the options you mentioned the Ranger swap would be the most difficult and time consuming. I would not attempt that one. I've read some comments about using the T-bird clip, so that may be a possibility. Before you make up your mind look into other options like AMC Pacer, Aerostar, Camaro/Monte Carlo, Volare, Dakota, and Mustang II. If I omitted any, sombody will jump in here and let me know. I, personally, like the Chrysler torsion bar suspension under these trucks than anything else. Most of these clips will give you power steering and disc brakes with possibly the exception of the Mustang II.
As long as the original frame isn't too hacked up, it will be much easier to change the rear and clip the front than to try a whole frame swap...
I agree with Vern. I'd keep the original frame so long as it's not too hacked up and just change the rear end and front clip. Changing rear end gears is not too difficult or expensive even if you have a shop do it for you. What gears are you considering? What gears do you have in it now? If it "winds" at 55, you likely have 4.11's or lower. Taller gears with the 390 motor are an obvious solution (2.72; 3.0; 3.08).
Regarding the front clip, Vern gave you a list of options. Much of your decision will depend on if you want your front end "slammed" or not. For adjustability, go with a torsion bar setup like the Volare or to air bag the front. This is not as expensive as it used to be and allows for on-call adjustability of ride height.
Good luck and welcome to FTE!!!
Daryl
'59 F100 with '88 Dodge Dakota IFS
Daryl
