my take on rims is this. If you go with deeper rims, you have to have the wider tires. This is the problem my son is having right now. He cannot go with smaller tires cause the rims are too deep. Cheapest I have found 33x12.5 here is $180 each. lotta dough for a 14 year old.
Not sure about what the manufacturers recommendation is on rim size but I think you are right inregards to the tire size. While these rims are stamped 15x8 on the inside, i measured and it was more like 8-3/8. Close enough... I will stick with what I got.
Do far so good... I have probably driven it about 100 miles or so... Still have the little nubs on the tread. Took it to the river bottoms which have large sandy beaches and watched 2x4s get stuck as I drove around them in 2wd... That was fun. All in all pretty happy. Kinda wishing I would have gone with 35's but just for aesthetic purposes.
Im glad they turned out well for you. Make sure to keep posting every now and then to report on treadwear and performance as you drive them more. Its hard to find good tire reviews like this one. Most of them are hearsay rather than people actually owning and reviewing the tires.
Hhmmmmm. Not sure. A couple thousand I would guess. Speedo has been out for a while with a laundry list of todos before getting to this. Not a daily driver. It should be though.
