Fault Codes?
Old May 3, 2014 | 07:48 PM
LariatPowerStroke's Avatar
LariatPowerStroke
Fault Codes?
I have a 2007 F250 6.0 Diesel I am having some fault codes pop up P0402 EGR Excessive Flow and the other is P0097 which it the IAT2 Sensor I replaced both less than a month ago due to the codes and now they are back any ideas?
Old May 3, 2014 | 07:59 PM
04badford's Avatar
04badford
Have you cleaned both? p0402 is saying EGR failure 0097 is faulty sensor ,you might want to double check the connection the little clips break off working the IAT2 connection loose. do you have a Gauge to monitor the EGR values?
Old May 3, 2014 | 08:05 PM
LariatPowerStroke
Both are brand new my old EGR valve was actually not that dirty but I replaced it and the IAT2 sensor I will.check the clips just doesn't make.since.since their both brand new
Old May 3, 2014 | 08:10 PM
04badford's Avatar
04badford
Were they both OEM by chance? wont be the first brand new part that was bad of the get. If you can get the values for both then that will scratch the PCM being the fault, next would be wiring chaff so look real close for that aswell
Old May 3, 2014 | 08:22 PM
LariatPowerStroke
I got both parts from.the FORD Dealer and which wires should I look at specifically
Old May 3, 2014 | 08:46 PM
04badford's Avatar
04badford
EGR Valve connection and wire harness laying on the Intake, IAT2 sensor connection and wires rubbing on anything? got a Gauge for sensor data ? like scan Gauge, torx app, dash boss any codes?
Old May 3, 2014 | 08:47 PM
04badford's Avatar
04badford
oops typed to fast already seen the codes I ment any data from Gauge would be helpful
Old May 3, 2014 | 08:58 PM
LariatPowerStroke
I have Scan guage and it just shows the codes
Old May 3, 2014 | 09:02 PM
04badford's Avatar
04badford
you will need to enter the Xgauges do you have the PIDs for EGR?
Old May 3, 2014 | 09:09 PM
LariatPowerStroke
I have the EOT and Trans Temp setup on the scan guage and what is the pids for egr?
Old May 3, 2014 | 09:19 PM
04badford's Avatar
04badford
let me see If I can get you the whole sheet Instead of typing them all hang on
Old May 3, 2014 | 09:22 PM
LariatPowerStroke
Thanks my email is Gomezj90@aol.com if that helps nit sure which codes I should have eventually wanna get some gauges to mount
Old May 3, 2014 | 09:30 PM
04badford's Avatar
04badford
Ford/Lincoln/Mercury Specific : Linear Logic : Home of the ScanGauge
these are the x gauges from ford there are also another one that's bigger , you will have to command the scan gauge to x gauge then enter each one, when you get EGR pids entered then do the test like this
koeo ( key on engine off)
low ( just Idle no radio HVAC on)
high ( 2500 rpm steady)
take note of these values like that with engine warm. I will see if Rusty or the guys have the other pid sheet
Old May 3, 2014 | 09:36 PM
LariatPowerStroke
Old May 3, 2014 | 09:38 PM
LariatPowerStroke
Awesome.thanks any specific one si should.keep an extra eye on?
