replacing shocks found problem
Old May 2, 2014 | 04:06 PM
jps47's Avatar
jps47
Changing my shock today, so far I'm on the back and sheared bottom bolt and top bolt is just spinning. Luckily on opposite sides so I got one on. Now I have the solid mount on top that I cant get bolt off cause it just spins. I tied pulling the shock to the side to get pressure on it but the exhaust was in the way. I think the po jacked me on this on by over torquing and stripping it. Anybody had this or any suggestions, If it was just a bolt I'd just cut it off but it isn't so . Also the torque spec on these are 46ft.lbs seem light to me.
Old May 2, 2014 | 04:59 PM
jspence105's Avatar
jspence105
Any Pics? If it's the top two bolts on the rear shocks they are just normal bolts and cagenuts. Being from MI it's probably rusted and the clip that holds the nut in place is broken so it just spins. Drill them out and get new bolts and cage nuts.
Good luck
Old May 2, 2014 | 07:20 PM
jps47's Avatar
jps47
Not just a bolt its a whole mount
Old May 3, 2014 | 09:42 PM
jps47's Avatar
jps47
Guess I need one of these http://www.ebay.com/itm/BRAND-NEW-OEM-RH-UPPER-REAR-SHOCK-BRACKET-FORD-EXCURSION-F250-F350-F450-F550-SD-/360644851075?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item53f81bb583
jazz77
Aug 16, 2016 09:33 PM
JimPat
6.7L Power Stroke Diesel
Feb 15, 2014 12:10 PM
fordsuperduty250
Dec 16, 2011 02:52 PM
greensocks
1983 - 2012 Ranger & B-Series
Sep 5, 2006 10:55 PM
99f350sd
Aerostar
Nov 15, 2005 07:49 AM
