falling flat 89 460
Old May 1, 2014 | 08:42 PM
mwkobe's Avatar
mwkobe
falling flat 89 460
Im working on a 89 460 that runs fine untill about 2800rpm and then it fall flat and missfires and get real sluggish even if i push the cluth in it wont stop missing until i let off th acc pedal then it fine until i go over 2800 rpm again.
wayne
Old May 2, 2014 | 08:21 AM
timbersteel's Avatar
timbersteel
When was the last tune up performed?
Have you checked for codes?
Could be catalytic converter plugged...ahh but that's an assumption without more info on the truck, like headers, no cats, etc. Give us more info on the engine and anything modified from the factory.
Old May 2, 2014 | 09:05 AM
Conanski's Avatar
Conanski
Check fuel pressure at idle, you should see 32-35psi and when vacuum line is removed from the regulator you should see 39-45psi. If pressure is low or drops below the idle measurement at any time the fuel filter is clogged, one of the pumps is failing, or the selector valve is failing.
Old May 2, 2014 | 01:06 PM
UNTAMND's Avatar
UNTAMND
Yes, please make a signature. It's very helpful when we know more info and stuff.
I'm going to suggest a combination of both previous replies.
Give it a full tuneup, with fuel filter, air filter, pcv valve, o2 sensor, plugs wires cap rotor, and run a can of seafoam in the fuel.
Check fuel pressure, and check for stored codes.
Old May 2, 2014 | 07:45 PM
mwkobe's Avatar
mwkobe
no codes resent tune up cat is rodded out. new tps ,coolant sens,egr not sure on fuel pressure
Old May 3, 2014 | 01:50 PM
F350 1990's Avatar
F350 1990
wayne
Fuel pressure is a leading culprit.
(Probably best to rule out fuel pressure first.....).........89 had that quirky out of tank high pressure pump with the dual selector valve........in 90 the 460's went with in-tank pumps........
Hotairjunkie
Modular V10 (6.8l)
Jul 8, 2013 10:39 AM
Immortal_Ben
53
Mar 6, 2013 01:28 PM
Mike450
19
Jan 21, 2013 02:35 PM
h2eter
43
Nov 3, 2012 05:19 PM
Dustin460
13
Aug 5, 2009 06:13 PM
