Minnesota Chapter Join Chapter, Leader: fordpower88
May BS Thread.....
Old May 19, 2014 | 09:23 AM
  #526
fordpower88's Avatar
fordpower88
Originally Posted by Devious Delight
I have an Aunt/Uncle down in Polk City. I'm sure I could get my uncle to take a peek at it for you, so no wasted trip down there.
Thanks Dustin! If I get more serious about it I may take you up on that.
Old May 19, 2014 | 10:01 AM
  #527
Devious Delight's Avatar
Devious Delight
no problem. I'd say give him a list of things to look for specifically. Might be able to get one of my other (more mechanically inclined) uncles that live in Des Moines to go look at it too.
Old May 19, 2014 | 10:36 AM
  #528
fordpower88
Sounds good! I will let you know. One thing I have to get past is I do not like the tan color of that two tone so that would have to get painted either white to match the rest of the truck or another color. I can paint it myself but there is still expense involved.
Old May 19, 2014 | 10:44 AM
  #529
Ford79's Avatar
Ford79
Originally Posted by DieselCamper01
I think I will put my truck on there too.
I am at a loss as to what could be going on still. Everything is tight and or new... The only thing I can think of is tires. They are new and load range E and all aired up to 70 PSI. Maybe too soft of sidewall???
I'd like to swap some tires around from my truck to yours to see if it goes away.
Old May 19, 2014 | 11:00 AM
  #530
DieselCamper01's Avatar
DieselCamper01
What's wrong with Arizona Beige??
Old May 19, 2014 | 11:01 AM
  #531
DieselCamper01
Even driving to work today I can feel it. Is it possible a tread separated?
Old May 19, 2014 | 11:02 AM
  #532
fordpower88
Just not a color I like.
How about swapping the front tires to the back and back to front and try that.
Old May 19, 2014 | 11:25 AM
  #533
Ford79's Avatar
Ford79
Possible, but I don't think so. Maybe a broken cord??? It feels to me like squishy side walls when driving it.
Old May 19, 2014 | 11:26 AM
  #534
dlibson's Avatar
dlibson
That's good! Have you got your other for sale on CL or is it sold already?
Up on craigslist waiting to go.
Old May 19, 2014 | 11:28 AM
  #535
DieselCamper01
Would that be visible just looking at the tire do you think?
I do plan to move the tires Troy and see if I can tell a difference. Just didn't work into the schedule this weekend.
Old May 19, 2014 | 11:30 AM
  #536
dlibson's Avatar
dlibson
You might be able to see it if you pick it up off the ground. Not easy to see loaded always.
I'd start by swapping tires around, but based on the clunk and it started after then, then gone and back with another feel hard to see. Unless something hit a tire when it went flying?
Old May 19, 2014 | 11:33 AM
  #537
dlibson's Avatar
dlibson
Troy, why not just find some fenders and the parts to convert yours? Less work than swapping everything over, and with all the work done to yours it might make more sense.
Old May 19, 2014 | 11:35 AM
  #538
wildstang's Avatar
wildstang
VT Chapter Ldr
This is almost the perfect truck for you Troy. Only flaw is the tan two tone
Old May 19, 2014 | 11:38 AM
  #539
dlibson's Avatar
dlibson
He needs a bigger camper.
Old May 19, 2014 | 11:41 AM
  #540
MisterCMK's Avatar
MisterCMK
Come out to the shop after work and we can rotate them.
