F6 Front Wheel Cylinder Source
I'm looking for either a rebuild kit for my front wheel cylinders, or the entire cylinder new. The vehicle is a 1950 F6, and my existing front cylinders are 1-3/8". (I think this is not the original size.)
I know the NAPA part number for the rear cylinders (1-1/2"): UP 4511
Does anyone know the NAPA numbers for the front cylinders or a rebuild kit?
Thanks!
Thanks!
Thanks!
Thanks!
No sure what the NAPA number is, I got mine from Amazon
The Wagner # is WC4571. Also make sure you save the adapters for the end of the hoses.
1948/52 F4/F5/F6 & F5/F6 COE / No Ford dealer or obsolete parts vendor has any.
Try: joblotauto.com in Queens NY. They're not listed on obsolete parts locator sites: PartsVoice.com & rearcounter.com.
BOT-2221-A .. Front Wheel Cylinder Kit-1 1/4" diameter - Use with 8T-2061 wheel cylinder / Obsolete
NOS PARTS SOURCE in Olathe KS has 1 = 913-220-5746.
MILLER OBSOLETE PARTS in Binghamton NY has 6 = 607-722-5371.
GREEN SALES CO. in Cincinnati OH has 6 = 800-543-4959.
I'm looking to re-plumb everything: new lines, cylinders & hardware. My "adapters" have seen better days - the threads are pretty worn. Thanks!
Would someone elaborate on the brake line setup for these cylinders, front and rear? Are the adapters non-standard? Would I be able to purchase new adapters?
The adapter is "brake cylinder inlet connector' part #91T2080a
Antique Auto Supply
1225 Colorado Ln.
Arlington, Texas 76015
Phone: 817-275-2381 supposedly they have 22 (updated 11/12/2013
Collectors auto supply
800-414-4462 supposedly have 2 (updated 2/17/2014)
If all else fails, try aircraft supply dealers for NSN#4730004312970
Update on the front brake cylinder hydraulic line adapter. Mine are worn/galled out, so I will be replacing everything between the cylinder and the 1/4" hardline on the frame.
The replacement cylinder (W4571) uses 1/2-20 thread for the hydraulic line. The threaded well is too deep for a common double-flare compression fitting; it won't tighten the line up. Even if it did, I need flex hose, not hard line.
Instead, I will use a 1/2-20 male to -3 AN male adapter on the cylinder, and then a 16" -3 AN female-female flex hose between the cylinder and the hardline. A -3 AN male to 7/16 double-flare compression (1/4 hardline) adapter will connect the flex hose to the hardline. I was able to find all these fittings at Summit Racing.
I'll update this weekend once I plumb everything. I hope at least some of the measurements above might help someone out!
livinjeep
04-30-2012 12:37 PM
jwsnell00
02-26-2012 09:02 AM
transam525
06-11-2011 12:21 AM
F2fan
07-21-2003 02:42 PM
