accelerator pedal goes dead
Old Apr 25, 2014 | 02:59 PM
jccapri's Avatar
jccapri
have been a weird problem make a hard right or hard left quick the accelerator goes dead check engine light comes onif you let off the throttle for just a few seconds the check engine light goes off And throttle comes backanyone have any ideals
let me add one other thing also I notice when I'm pulling my 24 foot trailer going up like heels if I accelerate I get a scraping squealing noisebut its only going up hills when you making a hard pull flatland it runs great the run up to 90
Old Apr 25, 2014 | 03:36 PM
montanasteve's Avatar
montanasteve
By hard left or hard right, do you mean turning the steering wheel to the limit, or just a quick turn into a parking lot? Easy thing to check first - make sure the PCM is securely mounted next to the parking brake assembly. May also have something to do with the gas pedal position sensor - the sudden let-off of the pedal may generate a short if that sensor's going bad? I'm just lobbing out ideas though, other guys may have better input.
As for the squealing going up hills, not so sure. Is the squeal from the engine compartment?
Old Apr 25, 2014 | 03:59 PM
Pikachu's Avatar
Pikachu
Do you have a way to read the stored codes?
Old Apr 25, 2014 | 05:12 PM
Pikachu's Avatar
Pikachu
On the noise, I'm going to go out on a limb and guess it's probably turbo surge. Ignore the part when the guy says, "listen to the waste gate," that isn't the cause. Does is sound like this?
Old Apr 26, 2014 | 06:50 AM
jccapri's Avatar
jccapri
7.3 powerstroke turbo surge ( in cab) - YouTube
Yes the video sounds like my truck going up a hill so what is that
Old Apr 26, 2014 | 06:53 AM
jccapri's Avatar
jccapri
Yes dummy me i well run codes should have done that frist
Old Apr 28, 2014 | 02:01 PM
jccapri's Avatar
jccapri
Ok here are the codes
P1249
P0221
P1211
P0541
What do i need to fix them and where they may be found .
Sorry for taking so long trying to move and work Thanks jon
PS what was the weird sound in the video my truck makes the same sound
Old Apr 28, 2014 | 02:42 PM
JOHN2001's Avatar
JOHN2001
Book mark this link you'll find it extremely useful when trouble shooting your truck Welcome to guzzle's Diagnostic Trouble Code list Web Page
Old Apr 28, 2014 | 02:46 PM
montanasteve
P0221 Throttle Position Sensor/Switch B Circuit Range/Performance
Old Apr 28, 2014 | 03:38 PM
jccapri's Avatar
jccapri
I know what the codes are my scanner Tells me that but does not go into what where or why like p0221 is it the 1 on the pedal Or the one under the hood
Old Apr 28, 2014 | 03:59 PM
Pikachu's Avatar
Pikachu
I believe switch B is the idle validation switch. If it's sticking and the PCM detects throttle movement, the truck will do nothing but idle, and set the MIL.
Old Apr 28, 2014 | 04:04 PM
jccapri's Avatar
jccapri
Where is it located at
Old Apr 28, 2014 | 04:20 PM
Pikachu's Avatar
Pikachu
It's part of the accelerator pedal assembly. Depending on the year, it's either a separate microswitch, or integrated into the sensor mechanism.
Old Apr 28, 2014 | 05:26 PM
jccapri's Avatar
jccapri
I have a 2001 F 350 Super Duty crew cab 4x4 lariat 7.3
Old Apr 28, 2014 | 05:54 PM
Pikachu's Avatar
Pikachu
It should be the type with the separate switch. If you stick your head at floor level, you should hear the switch click on and off as you press and release the pedal. It should happen within the first 1/8" of travel or so. If you press it repeatedly and there's a time you don't hear the switch click, it's sticking. If that's the case, you might be able to get some electronics cleaner and spray it in there. Just FYI, the switch has a 2 pin connector on it, and the sensor mechanism has a 3 pin connector.
