1950 F3 Steering Box New/Rebuild
Before I just go an buy something random from the web, does anybody know of a solid source for a new/rebuilt steering box? Mine is getting pretty hard to drive.
If anybody has any tips or trick, I am all ears. The steering wheel moves 4-5 inches either way without engaging anything. I have tightened the 5/8 bolt on the top as much as it will turn.
Thanks in advance for any suggestions.
Chucks Trucks LLC - give him a call and he can likely hook you up with a serviceable used one.
If rebuilding yourself, you'll need something akin to the Ford 7C-3548-KIT from DC: https://www.dennis-carpenter.com/tru...ox-rebuild-kit
The following users liked this post:
Unless it is worn .
Oh yeah, also check for wear or weakening springs in the drag link, factory spec is to bottom out the plug screws and then back it off to the closest position to insert the cotter pin. You do actually have to take up wear in that if it hasn't been lubricated so good. Could also be junk tie rod ends as well.
You can get a dedicated drag link socket that's just a huge driven screwdriver, but they're hard to get now. I just used a big crowbar as a breaker bar to move the cap.
Before you replace, adjust following the correct procedure. Here’s the page from the maintenance manual on setting the preload.
And this video shows how to adjust the free play.
Once you adjust free play, check for binding at the extremes of the steering. If the gears are worn, you might have proper adjustment in the center, but binding at full turn right and/or left. Then it’s time for replacement.
On my 48 F1 I didn’t need to adjust preload, only the free play. Note that these are not like modern cars, there will be some free play, just watch driving scenes in old movies and you’ll see folks turning the wheel constantly, that’s how they were.
Good luck.
Good luck.
honda_man_300ex
09-08-2010 07:29 PM
packrat56
04-13-2007 02:51 PM
