1978 - 1996 Big Bronco
eec iv
Old Jul 4, 2003 | 08:55 PM
Chris_ce's Avatar
Chris_ce
eec iv
anyone know what eec iv does.have had people tell me that some of them got it and some not but they don't know why.
any help
Old Jul 5, 2003 | 01:46 PM
steve83's Avatar
steve83
eec iv
The "Engine Electronic Control, generation 4" is the computer that controls the EFI (and some carbs in the mid 80s) and electronic automatic transmissions. It appeared around '84 and was used all cars & trucks until '96, when all trucks under 8500 lb GVWR and all cars went to OBD-II. The heavy trucks went OBD-II a year or so later.
Old Jul 5, 2003 | 01:56 PM
Chris_ce's Avatar
Chris_ce
eec iv
ok but what should that matter on plug wires and dist cap rotor
Old Jul 5, 2003 | 02:05 PM
FTE Ken's Avatar
FTE Ken
eec iv
What, exactly, are you asking? I'm having a difficult time deciphering your question (not even sure it was a question because it had no punctuation).
Old Jul 5, 2003 | 02:08 PM
steve83's Avatar
steve83
eec iv
I agree. Try to write in proper English using standard punctuation, or as close as you can. You didn't ask ANYTHING about plug wires, cap, or rotor, so I didn't say it mattered.
Old Jul 5, 2003 | 03:38 PM
mrwizard's Avatar
mrwizard
eec iv
Apparently it does matter for distributor cap, etc... I had the same issue the first time I bought tune-up stuff for my '85 Bronco. They asked if it was EEC-IV or not. I had no idea so I just went out in the parking lot and looked at the spark plug wire connections on the distributor cap. Went back inside and bought the right one.
Old Jul 5, 2003 | 03:55 PM
Chris_ce's Avatar
Chris_ce
eec iv
I'm trying to find out what the eec-iv is and does.I've benn told that it is on some broncos and some it is not.I'm tring to find some better parts for my bronco than the factory stuff.
When i went to the parts store to get cap,rotor,and plug wires they asked if it was eec-iv.I said that it wasn't and they said they didn't have the parts.They had the parts if it was eec-iv.
My question is what is eec-iv and what does it do,also why does it take different parts?
Old Jul 5, 2003 | 03:59 PM
steve83's Avatar
steve83
eec iv
I told you what it is & does in my first post. What year is your truck? What engine? Does it have a carburetor or is it EFI? The distributor on a computer-controlled engine has no internal advance mechanism, so it's made differently and takes different parts.
Old Jul 5, 2003 | 04:15 PM
Chris_ce's Avatar
Chris_ce
eec iv
Sorry should have stated that.I have a 87 bronco 351w ho.
It does have a carb.
The parts place said that it didn't matter if it was eec-iv for the dist cap, but it did for the plug wires.
So if the dist cap is the same for both why wouldn't the plug wires be the same?Is there something specail about the plug wires?
Old Jul 6, 2003 | 02:29 AM
1pump's Avatar
1pump
eec iv
An '87 with a carb? That seems a little weird to me. I've never seen one. Never seen one without EEC-IV either.
Old Jul 6, 2003 | 01:19 PM
steve83's Avatar
steve83
eec iv
The 351W didn't go EFI until '88, along with the 460. The 302 was available as EFI as early as '84, but it and the 300 went EFI in '87.
The plug wires shouldn't be significantly different (maybe size or resistance), so buy whatever they have. If you're worried, go to a better parts store and get the right ones.
