Low fuel pressure at fuel rail
While troubleshooting my rough running 89 F250 5.8L, I finally checked my fuel pressure at the rail.
+/- 25psi, +/-32 with vacuum disconnected fro regulator.
I actually lost fuel pressure a time or two and was able to determine that the frame mounted pump was running, but the in-tank pump was cutting out every now and then, all while the pump test plug was grounded.
Can a faulty in-tank pump cause low pressure at the rail?
vee-eight-fords
06-07-2004 09:22 PM
