351W(Injected) Hard Start
Old Jul 4, 2003 | 05:31 PM
brockmo's Avatar
brockmo
I've got a made for california 1995 f-150 with problems. During the last year the truck has had a hard start problem. This problem occurs most often when the engine is warm. If engine is cool it usually starts right up. Often during a long-cranking start, there is a brief puff of smoke from the exhuast. I've recently put in two new fuel pumps, fuel filter and fuel pressure regulator. Cap & Rotor and spark plugs are all fresh.
Old Jul 4, 2003 | 07:46 PM
pfogle's Avatar
pfogle
When was the last time you put an air cleaner in it? Have you pulled the codes?
Old Jul 5, 2003 | 01:51 PM
brockmo's Avatar
brockmo
The air cleaner is fresh. I've run a diagnostic and didn't find any codes. Also, during a long-crank start there is a slight smell of fuel in the engine compartment.
