6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
DPF-R 4.0
Old 04-08-2014, 09:14 PM
AndyW86's Avatar
AndyW86
AndyW86 is offline
DPF-R 4.0
Need help. Recently tried to install the Gear Box Z 4.0 dpf delete and it would download for about 20 mins and then say error code 88. any help thanks
Old 04-09-2014, 05:08 AM
senix's Avatar
senix
senix is offline
Received 1,418 Likes on 1,013 Posts
I think you need to contact gearbox z on this one. There are several that have the DPF R but no know has ever indicated any problems that I am aware of.
Old 04-10-2014, 10:27 PM
Greg B's Avatar
Greg B
Greg B is offline
I would contact Gearbox on this. I had an error code when I tried to install mine. I called them and they told me to turn the key to the run position before I plugged in to the diagnostic port. I did and the programmer loaded.
Old 04-16-2014, 10:18 PM
DrtTrkr's Avatar
DrtTrkr
DrtTrkr is offline
When I put mine in the voltage was low. I put a charger on the battery when I did the download and then it worked.
Old 04-17-2014, 09:20 AM
9228.bobcat's Avatar
9228.bobcat
9228.bobcat is offline
I used a gear box before I got my sct and it came up with an error code. Cant remember the exact code but I called them and they sent me a new one over night and sent them the old one back. They will take care of you.
olyellow
1983 - 2012 Ranger & B-Series
08-26-2015 07:50 PM
AndyW86
1999 to 2016 Super Duty
04-08-2014 09:05 PM
Domestic_Nuwbee
03-01-2011 05:00 AM
rtazz17
12-31-2009 05:06 PM
Staceman
Aerostar
07-11-2002 11:35 PM
Quick Reply: DPF-R 4.0
