Bronco II Ford Bronco II
front end Camber
Old Jul 4, 2003 | 02:55 PM
baddmove's Avatar
baddmove
front end Camber
Happy 4th all!!!!! i was wondering, do any or all of you BII owners have real noticable camber on your front ends?
Mine seems like the bottom of the front wheels are IN too far..kinda looks likes this \ / almost to that extreme......is there a way i can adjust this? mine is an 87 4x4, 2.9 Edie Bauer,manual trans.....thanx all..................Bob
Old Jul 4, 2003 | 03:14 PM
baddmove's Avatar
baddmove
front end Camber
Also...I have the chilton for BII's and rangers and it only SHOWS tha camber adjusting nut...not how to adjust it....thanx again...........Bob
Old Jul 7, 2003 | 10:13 AM
mrshorty's Avatar
mrshorty
front end Camber
On these TTB front ends, camber usually isn't adjusted using a nut. It is adjusted by changing out the camber adjusting bushing on the upper ball joint. The usual procedure is to measure the camber, remove the current bushing and (hopefully) read off the amount of eccentricity, then, from that and the camber measured, determine the correct bushing to put in, get it, and reassemble the front end.
