Sponsored by: Real Truck
Trans Problem
Old Jul 4, 2003 | 02:54 PM
Paul Bevis's Avatar
Paul Bevis
Question Trans Problem
99 Ford Diesel 7.3 with Banks exhaust brake and smart lock. Went down an 8 degree hill with 15,000 lb. load (truck & trailer) in first gear, auto transmission and first gear went out. Was it problems with Ford Transmission or driver error?
Old Jul 4, 2003 | 06:24 PM
Shakeable's Avatar
Shakeable
Trans Problem
Depends on how fast you were going at the top? Did first gear come back after the tranny was no longer red hot? Hehe. Does it have other gears? I would have thought it would have damaged the clutch on tourqe convertor before it smoked first gear. So that would tend to indicate you had a problem before you hit the hill and the hill revealed it. Of course a style of driving could have caused the problems before you got to the hill too.
Old Jul 5, 2003 | 06:35 PM
Ponyracer's Avatar
Ponyracer
Trans Problem
Hello,
Actually Neither! Sorry to be the bearer of bad news, I have seen this problem many times. The exhaust brake of any manufacturer causes the low/reverse clutch pack(which the smallest set of clutches in the trans) to work beyond their capability and literally burn up and in some cases I have seen them discintergrate(sp?). The Ford system is not designed for using an exhaust brake even though the after market insists that it will work and not void the Ford warranty. I would not be supprised if the local Ford dealership has not advised you of this as there is a Ford Oasis message that states that Ford will void your warranty if such aftermarket performance enhancers are added to the drivetrain and there is a failure.
Sorry your are having trouble, but I hope this information helps,
Old Jul 8, 2003 | 01:08 AM
Paul Bevis's Avatar
Paul Bevis
Trans Problem
Hi,
Thanks jim for your reply, it did help. You say the Ford system is not designed for the exhaust brake. Does that also mean 2nd and 3rd, because I have used it in 2nd & 3rd and have not had any trouble so far. Also are low/reverse the same clutch pack or are thay separate. A Ford Trans Technician in Eureka told me they were separate, but other machanics have told me they were the same.
Thanks again for your help.
Paul
Old Jul 8, 2003 | 06:13 PM
Paul Bevis's Avatar
Paul Bevis
Trans Problem
Originally posted by Ponyracer
Hello,
Old Jul 9, 2003 | 01:24 AM
Ponyracer's Avatar
Ponyracer
Trans Problem
Sorry was tired when I replied,
It is the Coast clutches that are usually toast because of the exhaust brakes. They are applied when in manual first gear.
In manual Second, the Coast clutches are applied but the intermediate band is also applied and will allow that gear to operate to some extent.
What is the smart lock supposed to do? I am unfamiliar with this version.
Old Jul 9, 2003 | 08:59 AM
Waxy's Avatar
Waxy
Trans Problem
IMHO, driver error. You simply asked A LOT more of the transmission than it was ever designed to do. In the end though, I place the blame with Banks.
I'm not sure that the Allison autos used in heavy trucks would stand up to comparable abuse.
Waxy
