emergence help needed
Old Apr 23, 2014 | 08:28 PM
Tailgate77478's Avatar
Tailgate77478
Have you checked your HPOP (High Pressure Oil Pump) reservoir to make sure there is oil to the top? If it is low or empty, you will need to add oil into the top of the HPOP reservoir with something small like a turkey baster (remove the bulb and use it like a funnel). If the HPOP was extremely low or empty, it may take one or two attempts of cranking at 15 seconds each. However, you will need to give your starter a minute or two between attempts. And of course, make sure you've charged your batteries up prior to attempting any of this. These trucks are very touchy if the battery juice is a little low. It should be Ohming out around 14+.
Old Apr 24, 2014 | 09:02 AM
Pitcrw6's Avatar
Pitcrw6
Sounds like the ipr is bad or the solenoid on ipr. I would get an ipr.
Godsarmy
19
Feb 21, 2018 08:09 AM
Skchurch06
Jul 5, 2017 12:49 PM
DentsideCurtis
Nov 8, 2016 10:36 AM
Rigormortise
60
Apr 30, 2013 06:30 AM
beersy50
48
Nov 13, 2010 04:51 PM
