Needing some wisdom..
Apr 15, 2014 | 09:07 PM
I`m pretty sure I have a bearing going out in the back of my Trooper. Can`t tell if it`s a wheel bearing or worse, in the diff. Anyone have a good suggestion on how to locate the offending bearing without tearing everything apart?
Apr 15, 2014 | 09:15 PM
If the fluid level is OK in the diff, I would be inclined to think it is a wheel bearing.
Apr 16, 2014 | 04:15 AM
Jack it up does the wheel move oddly?
Apr 17, 2014 | 07:11 AM
put it on heavy duty jack stands and anchor it, and have someone put it in gear while you listen closely to where the sound is coming from.
Apr 17, 2014 | 07:12 AM
bring it to the house some time, we can load it up on the trailer, anchor it to the trailer with tie down straps, and put it on my jack stands,
Apr 21, 2014 | 07:17 AM
Did you have a chance to check it out yet?
Apr 22, 2014 | 08:31 PM
Not yet.. Too dang busy..
Apr 23, 2014 | 09:03 AM
Are you sure it isn't a u-joint?
Apr 23, 2014 | 08:45 PM
Not really but is has the bearing "growl" to it..
May 4, 2014 | 09:02 PM
Culprit found.. Passenger side rear. Leaking brake cylinder may have been the thing that started it all..
May 5, 2014 | 05:13 AM
May 5, 2014 | 06:41 PM
Thanks! me too! I also am needing new brake shoes and pads so I guess it`s time to get dirty.
busdriver47
Apr 30, 2019 03:11 AM
dcjcdc
Escape & Escape Hybrid
Sep 24, 2016 11:15 AM
hughd
Apr 12, 2015 07:38 AM
acf6
Jan 21, 2013 07:54 AM
GWB
May 31, 2001 11:01 PM
