223 Won't Idle
Old Apr 14, 2014 | 07:52 PM
GeeeMCeee's Avatar
GeeeMCeee
223 Won't Idle
After a bit of cleanup and adjustment the 6 cyl began to run fairly well, but wouldn't run with less than about 1/4 choke. I decided to rebuild the carb, ordered a kit from Mike and followed his videos, installed the carb and it runs exactly the same. Can't find any vacuum leaks, is this a timing issue? My skills are tested and found wanting. Anyone have any thoughts?
Old Apr 14, 2014 | 10:29 PM
Maltman's Avatar
Maltman
Are you able to get any adjustment out of the idle mix screw?
Old Apr 15, 2014 | 05:26 PM
GeeeMCeee's Avatar
GeeeMCeee
tried the idle screw in and out and in and out, seems to have no effect. Clutch works!
Old Apr 15, 2014 | 05:36 PM
Maltman's Avatar
Maltman
If no adjustment at idle screw, my first thought is a clogged passage way somewheres? carburetor is acting exactly like mine when I first got my truck, in my case the cork bowl gasket came apart and junk was throughout my carb-but I rebuilt mine and replaced vacuum advance diaphragm and that took care of problemo
wish I could help ya more
Joe
Old Apr 15, 2014 | 07:50 PM
GeeeMCeee's Avatar
GeeeMCeee
Thanks Joe, I've been thinking about the vac advance, could be a leak, I was very careful to clean the carb when it was apart.
cstephens
Feb 18, 2018 07:49 PM
gordo2
Aug 31, 2015 11:01 AM
silver777
Nov 2, 2010 05:21 PM
Tony G
Jul 18, 2004 12:53 PM
dprasse
Aug 19, 2001 11:01 PM
