a quick 400 question
Old Apr 17, 2014 | 02:47 PM
BuzzLOL's Avatar
BuzzLOL
. We need a little more info... is that a 400 built in 1970-1971? Or the later smog 400's with iron emissions bosses blocking the exhaust ports, low compression ratio, and retarded cam timing? Early ~9:1 compression ratio, smog engines prolly down in 7's:1
. 4 bbl. intake/carb. and headers on the early engine will give around 300+ HP... same parts on the newer engines along with advancing the cam timing at the timing chain will give about 200-225 HP... plus grinding out the exhaust bosses, maybe 225-250 HP...
. See Tim's new 'Carb. and Intake Shootout' thread he's doing right here to see what better pistons and a cam can do for you...
. Check your local swap meets for a 650-750 CFM carb... the 600 carb.s often have idle circuits that are too small to get working right on a 400"...
. What state or country is your Munger in?
Old Apr 18, 2014 | 11:33 PM
buzzy613's Avatar
buzzy613
It's a 77 400 or 76 and its in Michigan home of the potato festival. I was told the motor was rebuilt not 100% sure what's all done to it
Old Apr 21, 2014 | 12:06 PM
BuzzLOL's Avatar
BuzzLOL
. I'm almost in Michigan... standard rebuilder pistons even worse than the stock ones...
Old Apr 21, 2014 | 12:55 PM
buzzy613's Avatar
buzzy613
I believe it
countryF150
Dec 17, 2006 09:36 PM
JBradley500
Nov 8, 2006 02:24 PM
flexybronc
29
Feb 10, 2005 10:25 PM
Franklin2
Mar 13, 2002 02:15 PM
jevanof
Feb 17, 2002 11:45 AM
