Gas Tanks
Old Jul 4, 2003 | 09:29 AM
mmorto's Avatar
mmorto
Trailering
Gas Tanks
Does anyone have an opinion on Stainless versus Poly tanks? I have to replace mine as some had taken it out from underneath and put it behind the seat in the cab. Would it be better to put it back stock or between the rails in the back?
Thanks
Old Jul 4, 2003 | 03:15 PM
DS02F250's Avatar
DS02F250
Gas Tanks
See my post under the recent thread entitled, "the Niolon Mustang Install". I have an aluminum tank behind the rear melon that I fabbed support braces for. My only goof-ups where: (1) I bought a top-fill tank when I should've got a side fill. As a result, I had to raise the bed floor so I could put a bend in the filler tube. Then I ran the filler tube to the filler door, which I incorporated in the rear 1/4 panel on the driver's side w/ pop-out door; and (2) I got the tank with the foam inside it. I got sold on the idea that it helps control fuel delivery. I've since come to learn that's good if you're in serious off-road or dirt-track competitions, but not at all necessary for daily driver's like mine. Also, the foam dispalces some volume, so my 20-gal tank only holds about 15 gals, making trips to the gas station all the more frequent.
Hope this helps. If you'd like to see pix of the support braces, E mail me and I'l shoot ya some.
Daryl
PS- aluminum vs. poly??? both provide the same function, so get one that fits your dimensions for your tank area and is affordable to you for the best quality you can afford.
Old Jul 4, 2003 | 05:35 PM
jniolon's Avatar
jniolon
old and in the way
Gas Tanks
Daryl,
I'd like to see the pics of your mounting setup.... you can never have too much information..
john
Old Jul 4, 2003 | 06:31 PM
DS02F250's Avatar
DS02F250
Gas Tanks
John,
send me your E and I will do so gladly!
Daryl
