2006 F-150 4wd module not working
Hi,
I have a 2006 F-150 Supercab King Ranch 4wd. The 4wd is not working. Took it to the dealer and they tell me the 4wd module is not communicating with the PCM. It is my understanding that this problem is rare...like 1 in a million. Ford wants to replace the entire PCM.
In the past, I have had electrical problems with this vehicle due to corroded wires. Any advice would be much appreciated before I go and spend 1500.00.
Thank you!
Thank you!
I also recommend a second opinion. I would go to an automotive electrical specialist ( if your near Manchester,ct I can recommend a great one) I would suspect a bad wire or wires abd some in-depth testing is needed to diagnose. Could be the switch,motor,trans case and any wires in between. Sorry I don't have the answer, but it may be easier abd cheaper than a pcm
I quite understand thats not the only things. I listed things that I knew and that ive had problems with and those are the majority problems. I dont want to list things ive never had an experience with
Thank you for your help. I live in Illinois. Lots of rust due to salt. I tend to agree with you that it is not the pcm, but very well could be bad wiring or a hub. I did inform them that I have had wiring issues. The problem with most dealers is that they prefer to change parts until they find the bad one.
One more question: do you know if it's possible to reprogram the pcm? Could be a dumb question.
Thanks again!
Thanks again!
Thanks again!
Thanks again!
