Sponsored by: Real Truck
Which Tonneau?
Old Apr 17, 2014 | 12:07 PM
  #31
Shovelheadrob's Avatar
Shovelheadrob
Originally Posted by 89LX306
I really like my Pace Edwards Jackrabbit. It seems to be a great cover. Of course I did get mine for free, so that makes it even better.
I really do like the look of this cover & I'm seriously thinking of upping my budget to cover it, the only concern is how much space at the front of the bed becomes redundant due to the canister, my custom Harley is only a couple of inches short of 8ft & I wanted to be able to put it in the back with the tailgate shut, maybe it will go corner to corner!
Old Apr 17, 2014 | 12:10 PM
  #32
RigTrash601's Avatar
RigTrash601
I read it takes 10" from the front of the bed, the Bak-Flip takes less than 6". (Read in on the Pace website).
Old Apr 17, 2014 | 12:27 PM
  #33
RigTrash601
Go here: Jack Rabbit then FAQ, "How does the Jack Rabbit work?" it states the cannister is 9.75" x 11" tall.
The makers of Bak-Flip also have a RollBakTonneau, their website state the cannister takes from 8.5" (max) to 6.5" Not sure of the price, they both look like nice tonneau's. Didn't know they (Bak-Flip) made a retractable tonneau, anyway look here also:Truck Bed Cap - FAQ
Old Apr 20, 2014 | 10:47 AM
  #34
Shovelheadrob
Well thanks again for all of your inputs, I've gone & ordered a Bakflip G2 Tri fold, I figured it is probably more versatile than a retractable cover & far more secure than a soft roll up. I plan on keeping this truck till I'm too old to drive so don't see the point in saving a few bucks on a cheaper product.
Old Apr 20, 2014 | 10:51 AM
  #35
RigTrash601
You can't go wrong there either, like I said, that's what we installed on my son's pickup, if it can handle him, it can handle pretty much anything. Very simple and quick to install and his has never leaked.
Old Apr 20, 2014 | 04:08 PM
  #36
Bandguy's Avatar
Bandguy
You might want to consider the Bak Box if you are going with the Bak G2. If you are a contractor it might not be enough to meet your needs but for tow ropes, basic tools, simple emergency equipment, other stuff you might not want rolling around the bed, I think it is great.
Bandguy
Old Apr 20, 2014 | 04:26 PM
  #37
dmallen's Avatar
dmallen
I just ordered my BakFlip F1. It will work perfectly for what I need it for and I don't have to lose any of my already-too-short bed when hauling things. Check it out...
BakFlip F1 Tonneau Cover | Bakflip.com
Thanx.
Old Apr 20, 2014 | 11:33 PM
  #38
prime81's Avatar
prime81
My experience between the G2 and F1 is the G2 is painted aluminum, so it dings up easily and fades over time. The F1 is fiberglass coated, and generally does not fade, the F1 is also slightly higher grade rubber than the G2. I've had an F1 and G2 go through a hail storm side by side and the G2 looked like someone took a hammer to it, the F1 looked good as new.
I'm dropping the new F250 off in the morning for the spray in liner and then I'll be installing my Roll-X cover with the Bakbox 2.
Old Apr 21, 2014 | 05:40 PM
  #39
prime81's Avatar
prime81
Here is the finished product with the Bak Roll-X installed.
Here it is fixing to be installed, just rails and bakbox installed.
And finally finished product, install went rather smoothly.
Old Apr 21, 2014 | 06:31 PM
  #40
jdadamsjr's Avatar
jdadamsjr
Yowser, that block your rear window when rolled up !?! Does it lock forward when rolled up ?
Wondering how will you see your fifth wheel hitch .... or are you getting a camera installed ?
Old Apr 21, 2014 | 07:34 PM
  #41
schrod's Avatar
schrod
I will take my soft Access tonneau rollup over that. It only blocks half as much of the rear window when rolled up.
Old Apr 21, 2014 | 07:59 PM
  #42
tcreek's Avatar
tcreek
I like the Roll and Lock. Custom fit to go with the tool box and have camera for hooking up 5th wheel.
Tom
Old Apr 22, 2014 | 09:39 AM
  #43
prime81's Avatar
prime81
It doesnt block anymore than my previous F1 did, if you have a mirror installed on the fifth wheel backing up is easy as pie. I may invest in a wireless camera to attach to the rear of the fifth wheel when I am double towing.
Old May 11, 2014 | 11:06 AM
  #44
Shovelheadrob
All fitted a couple of weekends ago
Really pleased with the quality & fit, I think my bike will go in with the tonneau up against the cab, haven't got a ramp sorted yet though to try it, next job spray in bed liner, I removed the plastic one & although there is absolutely no rust in the bed, the paint is gone in a couple of places & I've never been keen on plastic liners anyway!
Old May 11, 2014 | 01:33 PM
  #45
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
shovelhead... your truck's black paint is in literally "brilliant" condition, especially being so many years old.
Can you post a picture of what your four panel folding top looks like when folded "up" so that the bed is as open as possible?
The manufacturer's of these folding tops rarely (if ever) put up pictures of what the top looks like when it is bunched up and folded against the rear cab window. It would be neat to see what a "real world" installation looks like when the cover is un-deployed in the open position, especially to determine clearance for fifth wheel trailers.
