Modular V10 (6.8l)
engine swap 99 v10 using 2000 v10
Old Apr 11, 2014 | 10:08 PM
Jnowaczyk's Avatar
Jnowaczyk
getting ready to do a swap i have a 99 f250 crew v10 donor engine is from a 2001 rollover v10 i notice that the egr is not on the donor and the carb is diff am i going to have any problems and should the 2 main elec plugs work
Last edited by Jnowaczyk; Apr 12, 2014 at 09:58 AM. Reason: wrong year on donor engine
Old Apr 11, 2014 | 11:51 PM
tims01's Avatar
tims01
swap what ever parts that need to be swapped .. i just took a rollover f250 v10 and put it in my e350 van .. van had egr truck did not .. used truck block and intake manifolds .. used van exhaust egr manifolds and throttlebody asembly from van egr also .. and swaped a few other things over .. its prety strait forward
Old Apr 11, 2014 | 11:55 PM
Jnowaczyk's Avatar
Jnowaczyk
ok thanks i was hoping i could leave the egr tube off
Old Apr 15, 2014 | 01:36 AM
Jnowaczyk's Avatar
Jnowaczyk
we does anyone know if i leave the 2001 complete with out the egr and buy a Mikes 5 star custom tune would fix any issues from not swapping the exhaust manifold and intake from the 99 and just run a hose from the heater core to the front i think that's all the difference getting ready to do this this Friday so please speak up soon Thanks guys
Old Apr 15, 2014 | 07:23 PM
tims01's Avatar
tims01
if your computer is programed to see an egr and you dont install it you will have a check engine light on until it is fixed .. and having egr is not that bad unless it is not in good working condition .. mine was good to go after 250,000 miles .. now that said if your place of living does a visual check and sees that the stickers on the valve covers or somewhere on the motor of hood says that this motor is equipped with egr and they dont see the egr you might fail that inspection .. just food for thought ... its just the one exhaust manifold and the throttle body and the intake ..
Old Apr 15, 2014 | 08:09 PM
Jnowaczyk's Avatar
Jnowaczyk
ok thanks we dont have inspections i contacted mike from 5tar tunes he can do a custom tune but i have decided to swap out the intake and do the exhaust manifold thanks for the comment
DarrellinCeres
Modular V10 (6.8l)
Sep 9, 2016 02:07 AM
Camden333
Oct 26, 2011 12:53 PM
Under Pressure
Modular V10 (6.8l)
21
Aug 27, 2009 03:06 PM
Ford_Eddie_Bauer
Modular V10 (6.8l)
Jun 30, 2007 02:50 PM
