1989 5.0-5.8 stock cams
on
1 Post
The E7TE heads were used on all pickups and vans with the 5.0 and 5.8 from 1987 to 1997. If you're planning a boost motor with more than 500 HP and going to abuse it regularly, then you need to go with a stronger block, at a minimum, a 68-79 302 block. All the 68 -79 blocks are identical in iron content, including the 289 Hi-Po and the Mex blocks, plus the lesser known D8VE-A3A casting, these three have beefier main caps. Other than the main caps, the iron content (weight) is the same as the other 68-79 302 blocks. These blocks have 10 more pounds of iron in them(136 lbs) vs the 86-2001 roller blocks (126 lbs)
on
1 Post
* I just wanted cam advise from somebody who actually played with this combo
I would never consider a 302 for what you're doing. 351W at a minimum for a starting point. 302's are NOT and never were intended to be truck engines. Trying to bandaid one to be a truck engine is asking for trouble. The 351 will yield the same mileage in a truck as the 302 anyway, so there's no point in using a 302.
on
1 Post
I would never consider a 302 for what you're doing. 351W at a minimum for a starting point. 302's are NOT and never were intended to be truck engines. Trying to bandaid one to be a truck engine is asking for troubl9e. The 351 will yield the same mileage in a truck as the 302 anyway, so there's no point in using a 302.
* I camp maybe 3 times a year. With the gooseneck hooked another 6 days. Hey I ditched the wife, now I have money, and I wanna play with it. 79 shorty needs a windsor. And my 77 scsb has a borrowed Cleveland in her right now. Picking my battles
on
The 351 on the other hand makes more peak torque stock and with a few cheap mods will make the kind of power the 300 simply can't compete with, and there is a massive list of aftermarket parts available to build as much power as you want. Plus it sounds cooler so I simply don't get the 300 love.
Like I said, why settle for the 300 when you can have the same bore & stroke, along with two more cylinders and better heads ? And far more cam choices ? Main bearings mean nothing as far as generating power. Touting that is akin to the Chebby guys touting their four bolt mains. If you're not making the power, you don't need them.
