Sponsored by: Real Truck
Front rotor removal
Old Jul 3, 2003 | 11:13 PM
NZumo's Avatar
NZumo
Front rotor removal
Yes I didn't change the pads soon enough and you know what I have to do now.... Does anyone know how they come off... "99" SD F350 4X4.. Just what I need to do over the 4th
I removed the cal, hub, and the cal housing. I also removed the clip and three washers on the axle after removing the hub. Do I have to remove the 4 bolts in the back of the assembly and then start banging. Do I need a wheel puller
Please help
Thanks, everyone
Old Jul 4, 2003 | 04:36 AM
HeavyAssault's Avatar
HeavyAssault
Front rotor removal
Ok try this trick: Remove wheel, Remove brake caliper, Pound on rotor till it comes loose.
I know it sounds too simple but there is no need to remove the hub assembly.
Old Jul 4, 2003 | 09:40 AM
99f350sd's Avatar
99f350sd
Front rotor removal
when you pull off the caliper bracket then you can get back there with a rubber mallot or leather hammer or mini sledge ans peice o wood.. Book says to have em checked of you beat on em to much.
Old Jul 5, 2003 | 10:48 PM
NZumo's Avatar
NZumo
Front rotor removal
Thanks everyone your awsome... it did sound toooo simple. Job complete.
Old Jul 5, 2003 | 10:51 PM
HeavyAssault
Front rotor removal
We are here to help.
Nighteyez
N. California Chapter
27
Jan 20, 2013 01:34 PM
TennesseeMustangPerf
Dec 17, 2010 02:51 PM
Kep4
S. California Chapter
29
Dec 7, 2007 06:30 PM
whits
Nov 18, 2007 08:24 PM
factory594x4
Jun 8, 2006 12:06 AM
