power steering pump
Old Apr 10, 2014 | 12:15 AM
just-n-time's Avatar
just-n-time
Angry power steering pump
this post has nothing to do with trucks, my daughter in-law purchased a Ford van and had the pump replaced, this is not the same system we had on our older trucks, it has a separate reservoir. now the trouble is, as long as the van is running the fluid stays and the power system works, but when you shut off the van the fluid flows out of the top of the reservoir.can any one lead me toward a fix?
Old Apr 10, 2014 | 12:17 AM
Jklnhyd's Avatar
Jklnhyd
Dont we have a van section? I think so
Old Apr 10, 2014 | 12:19 AM
rockittsled's Avatar
rockittsled
It sounds like it is not fully bled of air. when the pump is running, the air bubbles in the system compress under the pressure, and when the pump pressure dies at shutoff, the bubble of air expands and pushes fluid back out. do you have a manual for the proper bleeding procedure for your van?
Old Apr 10, 2014 | 01:12 AM
just-n-time
no I do not have a manual. I did not do the work when the new pump was put on. though the air not venting dose give me something to think about. She should be over some time this morning. I will look for some place to vent the air.
Old Apr 10, 2014 | 01:44 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
What year is the van, which I assume is an Econoline?
Old Apr 11, 2014 | 09:50 AM
jredline1984's Avatar
jredline1984
A1CARDONE: Vacuum Bleeding
Old Apr 12, 2014 | 01:53 PM
just-n-time
power sterring
this is a windstar 2001 v6
Old Apr 12, 2014 | 02:35 PM
BuzzLOL's Avatar
BuzzLOL
. Sometimes driving slowly in a parking lot and turning the wheels lock to lock a few times will get most or all the air out...
weekendwarriorfsw32
Sep 28, 2009 03:45 PM
mikedoughty
3.8 & 4.2L V6
Apr 7, 2006 07:51 AM
woods
Mar 16, 2006 08:04 AM
ct.russ
Nov 15, 2005 06:52 AM
