Hello all. Question. Are the 98,99 ford e350 extended passenger van the same in interior carpet as a 2004 ? Reason I say because my van came with the rubber flooring, and I wanted to order the carpet from stock interior. But they only offer for yrs 92-99. Thanks
The outline or footprint should be the same from '92 all the way through 2013. I could be wrong but they should all be the same.
The main difference might be cut outs for rear seating which may have changed from one model year to another. Perhaps colors for the years available has something to do with the limited year coverage?
FWIW I'm right now driving an '03 E250 EB with plywood floor cut to fit with rubber mat from a '98 E250 EB---fits like a glove.
I figured. Thanks JWA! Not to worry about cut out as the carpet comes uncut and I plan on installing captain seats in rear . Taking out the heavy bench seats
Well, maybe and maybe not. The 92-96 vans have a different doghouse and doghouse cut out than the 97 up vans. Don't be surprised if you have to trim or change the front a bit. Other than that the floor footprint of the vans should all be the same.
