quick question
Old Apr 7, 2014 | 10:23 PM
66f250's Avatar
66f250
quick question
Hey guys I picked up a 79f250 so I can swap out the front end of my 66f250. I have the master cylinder, and break booster all switched over. Now time for the twin I-beams. A friend of mine said that i could just swap the spindles, rotters, ect. Not the complete I-beams, and save some time. I never heard of this before. Any truth to that thanks?
Joe.
P.S. I want to use the power steering gear box also.
Old Apr 7, 2014 | 11:35 PM
garbz2's Avatar
garbz2
Yes. Spindles swap. you may need to grind a bit off the top of the tie rod mount to fully seat the tie rods.
Garbz
Old Apr 8, 2014 | 09:21 PM
66f250's Avatar
66f250
Thanks Garbz. Ill get started on that.
Joe
Old Apr 9, 2014 | 04:32 AM
jowilker's Avatar
jowilker
Joe, Don't disagree with what has been written, except for saving time. I have seen a single king pin beat on for a half of a day.
I say swap the complete set and when you connect the steering gear back you will have a matching set.
John
Old Apr 9, 2014 | 06:53 PM
66f250's Avatar
66f250
Do you think I should take all the steering linkage out of the 79 also? Tie rods, drag link, ect.
Joe.
Old Apr 10, 2014 | 04:44 AM
jowilker's Avatar
jowilker
Joe.
Joe, If you are going to a Saginaw power steering gear you will have to. The connect point is 2 1/3" closer to the firewall because of the hose connectors on top of the gear.
John
66f250
Jun 8, 2018 10:45 AM
Old Coyote
May 8, 2015 08:48 AM
Witty73
16
Jan 19, 2012 07:16 AM
rebocardo
Sep 26, 2002 09:36 PM
strawboss
Aug 26, 1999 07:33 PM
