Found NOS part #c1tt-7a5722-d . It does not line up with frame side bracket,no place to attach retracting spring? I am seeing 3 different versions of this part? Anyone?
1961 Ford F100 unibody original 292 engine and orginal 3 speed transmission on the column.
Found NOS part C1TT-7A572-D (1961/64 F100/250 292 2WD).
It does not line up with frame side bracket. No place to attach retracting spring? Not supposed to be, look at 7542 in parts catalog pic.
I am seeing 3 different versions of this part? Where?
1961 Ford F100 unibody original 292 engine and original 3 speed transmission on the column.
Was there a paper tag with this part number printed on it glued to the pivot?
Or was therea tag wired to the part with this part number hand written on it?
Or was there no tag of any kind with a part number on it? If so .. you believed what the ebay seller said it was: C1TT-7A572-D
Most ebay sellers haven't a single clue what parts fit!
This is supposed to be the engine side equalizer (Z) bar pivot. What is the condition of the frame side pivot, equalizer (Z) bar split bronze bushings?
Left: Exploded view of the whole enchilada / Right: 7A572 1957/63 truck parts catalog applications.
