F2/3 Bed, need some pictures
I'm looking for some pics of the how the front panel of the bed joins the side panels, mine was in pieces when I got it. There is a row of holes up the sides, bolts or rivets? On the round tube on top of the front panel mine has obviously been welded together, badly. Are they meant to be welded here? Seems strange to put bolts up the sides and then weld the top.
Bed pics F2
Hi
Hope these help. The sides are riveted and the top corners on my F2 are welded.
The edge of the front panel is rolled and I presume spot welded together.
https://www.dropbox.com/s/eh86mfr27e3gawo/IMG_0762.JPG
https://www.dropbox.com/s/6ag0uf19tnn0ez5/IMG_0758.JPG
I absolutely agree that riveting isn't difficult. But I have seen nicely restored trucks that had had the front bed panel removed and poorly re-riveted back in place. The original rivets were set and heavily flattened on the inner side with a waffle bucking tool. The rivet has the distinctive waffle markings. Model A's apparently used a lot of rivets with waffle bucking. The tool is available today from several sources I think. Here is a picture and link to one site I found. Stu
Waffle Tool
Edit - here's a picture of it. Stu
Waffle Tool
When I repaired the frame on my project M-H I used a section of 1/2" flat plate and drilled/ground indents to accept the formed head of the rivet, then clamped the plate in position holding the rivet. I then heated the shank and used the air gun with bucking bit to form the other head. In your example I'd bolt the bed together then, removing one at a time and supported by a wide bar clamp across the span of the bed, use the waffle bit in your air gun and torch to set the inner head. Might take some practice but should yield good result. You can see in my picture that even at the factory the bucking bar slipped off the rivet sometimes. Stu
FuzzFace2
15
12-18-2017 04:23 AM
Skalywag
15
06-01-2014 09:52 AM
John_deere_kid
07-26-2008 09:48 AM
