Door lock mayhem
Old Apr 3, 2014 | 10:21 AM
For-dragon's Avatar
For-dragon
Door lock mayhem
So my first project was to tackle changing the door locks (as the ignition works, but the key doesn't fit the doors and there's only one key).
Upon opening the door I found tons of leaves and this:
Someone along the line either lost, removed, or ate the linkage and the lock and core are held in not by clips, but by a black, tar-like putty. After I cleaned out the leaves I found one complete linkage and clips, but i'd like to replace the set-up if I can; I also need the other side.
Bill, do you or anyone else know of any NOS avaliable for this? I have new lock cylinders, I basically need everything from those to the door. (I found the part numbers in another post, but cannot find that post today, sorry).
Old Apr 3, 2014 | 02:52 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Scroll down to see parts catalog pic.
A boneheaded former owner lost the retainer (22023) that retains the lock cylinder to the door...so used putty instead.
Also missing is the link rod (22152) from the cylinder to the latch and the clip (21952) used to retain it. The control link (21954) is present on the cylinder, but is it any good?
If you peel back the door weather strip slightly, you can see the hole where the clip fits to the cylinder.
1961/66 F100/1100 - 1963/69 N/NT/T500/1100 -1967/69 F800/1000:
B9AB-6421954-A .. Door Lock Cylinder Control Link-R & L same / Obsolete
NOS PARTS LTD in Waxahachie TX has 15 = 972-937-2201.
GREEN SALES CO. in Cincinnati OH has 30 = 800-543-4959.
C1TB-8121952-A .. Link Rod Retainer Clip-Right Side / Obsolete
COLE MOTOR SALES in Ada OH has 4 = 419-634-3831.
BELL-MCCALL CO. in Hamilton MT has 8 = 406-363-2011.
DICKERSON MOTOR CO. in York SC has 18 = 803-684-4225.
C1TB-8121953-A .. Link Rod Retainer Clip-Left Side / Obsolete
BELL MCCALL CO. has 5.
COLE MOTOR SALES has 11.
C4AZ-6202023-A .. Door Lock Cylinder Retainer-R & L same / Obsolete
DON SANDERSON FORD in Glendale AZ has 9 = 623-842-8643.
GREEN SALES CO. has 19.
C1TB-8122152-B .. Door Lock Cylinder Link Rod-R & L same / Obsolete
COLE MOTOR SALES has 1.
GREEN SALES CO. has 2.
NORTZ & VIRKLER FORD in Lowville NY has 2 = 315-376-6594.
Old Apr 3, 2014 | 07:51 PM
For-dragon's Avatar
For-dragon
Perfect. Thanks very much kind sir.
janschutz
Dec 8, 2018 08:40 AM
daveengelson
Nov 6, 2017 02:21 PM
qman
15
Sep 8, 2017 06:12 PM
tiim5
13
Dec 2, 2016 03:47 AM
Vashon Islander
Aug 26, 2014 10:25 PM
