Holley 4BBL on a 64 292??
Old 04-02-2014, 02:48 PM
1964FORDTUF's Avatar
1964FORDTUF
1964FORDTUF is offline
PO of this truck was kind enough to provide some good records. At some point, the 292 was rebuilt, bored .060 over, crank .010 under, allegedly installed large valve heads, stock 4BBL intake, but it has a Holley 4 barrel on it. Which I know at least needs rebuilding but also think maybe to much CFM. What did Ford use for a stock 4 barrel carb back then?
Old 04-02-2014, 07:38 PM
svolpone's Avatar
svolpone
svolpone is offline
i have a holley 560 cfm 4 BBL on my 292 and it seems ok. i don't know what the PO did to the engine, though.
Old 04-02-2014, 09:37 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
1957/64 292 Heavy Duty came w/a Holley 4V
Old 04-03-2014, 02:09 PM
1964FORDTUF
Thanks. Any chance of the correct model (4160?) or part number? Would be interesting to know if mine is at least era correct.
Old 04-03-2014, 02:38 PM
NumberDummy
All I can give you is the Ford & Motorcraft part numbers and a parts catalog picture.
C3TZ-9510-A .. Holley 4V Carburetor (Motorcraft CA-241-A) / 1963/64 292 / Obsolete
The problem with FoMoCo parts catalogs: There is no Holley number listed.
Old 04-03-2014, 03:02 PM
svolpone's Avatar
svolpone
svolpone is offline
the holley site has a wizard for you to walk through that will give you the correct carb. try that.
Holley Interactive Carburetor Selector
Old 04-04-2014, 05:58 AM
1964FORDTUF
ND - Thanks as always, this is very helpful.
weldworks
23
10-23-2018 03:32 PM
vze2c2gb
10-10-2014 08:05 PM
46yblock
WTB - Parts & other
02-21-2012 09:53 AM
twise
09-02-2008 10:03 PM
blackestheart
04-15-2006 10:10 PM
Quick Reply: Holley 4BBL on a 64 292??
