That pic is making me want more lights now. Sharp truck.
Originally Posted by Bazillions
Where did you mount them, the vertical flange underneath?
I'll go take a picture and add it here in just a bit. But yes it is just right where it shines down on the board good. Right where it starts to come down.
On some of the trucks there is a plug on the frame that you can use a metra speaker adapter to tie into. But yes it is the dome circuit.
Thanks! Unfortunately I have an 07 and no plug. You should look at duraflaps instead of the factory mud flaps.... They provide way better protection (and look way better IMO) plus The factory ones scratched up my paint really bad.
I know you have a light bar picked out but this is what I used and IMO its a much cleaner look,I don't like to see the plastic bar.I will tell you the lights are BRIGHT.
