Yorick - the build thread
Old Aug 29, 2014 | 08:03 PM
Lloyd399's Avatar
Lloyd399
ignition upgrade
Upgraded the ignition last week to a pertronix unit and thankfully got rid of that funky ignition resistor that some PO had put in line. Thanks to the forum, when the condenser went out and the truck wouldn't run I pretty much knew what was going on!
Also replaced the driver side door window gaskets, regulator and rebuilt the hinges. Door now shuts with one finger and I don't have to do the shoulder bump to open it from the inside anymore. Getting the door off was a bit fun. I figured out why it was off so much. Apparently the pin had backed almost all the way out of the hinge.
Now if I can just find time to get the truck to my buddies shop to get the headers installed and new exhaust system....
Next big upgrade will be the front brake system. Already have the Scarebird brackets. That will take place during the next break from work. I'll make sure i take plenty of photos during the conversion process in case anyone is interested.
Old Aug 29, 2014 | 10:35 PM
quinletc's Avatar
quinletc
Alas, poor Yorick, I knew him well...
Nice truck!
Old Aug 30, 2014 | 01:56 PM
JEFFFAFA's Avatar
JEFFFAFA
Good job on the body work. Looks like you got 99% of it straight. That must make you one of the 1%ers.
petehf100
Jan 31, 2019 08:59 AM
sdrob15
Nov 11, 2018 09:20 AM
thepitshop
24
Sep 22, 2016 07:56 PM
96grimreaper
Nov 8, 2013 02:18 PM
Jeff55F100
Jul 18, 2012 11:21 AM
