Crew cab doors
Old Mar 30, 2014 | 05:46 PM
JackErnie's Avatar
JackErnie
Crew cab doors
I'm restoring an '86 crew cab 4x4. Would all the doors (front & rear) from a '97 crew cab fit my '86?
Old Mar 30, 2014 | 06:20 PM
Redneckfordf2502002's Avatar
Redneckfordf2502002
I may be wrong but I don't think they will because of the set up of the windows on the 86 compared to the 97s.
Trav
Old Mar 30, 2014 | 06:26 PM
JackErnie's Avatar
JackErnie
Thanks for the info.
Old Mar 31, 2014 | 07:22 AM
craftsmangary's Avatar
craftsmangary
I've done this swap. I used the 97 windows, but had to do some work to the inside of the shell to make the 86 door panels work. I did this about 15 years ago so I'm not exactly sure what I did, but it is doable.
Old Mar 31, 2014 | 10:02 AM
JackErnie's Avatar
JackErnie
Thank you! Will let you know (in a couple months when the snow leaves) how it turned out.
Old Mar 31, 2014 | 02:36 PM
DIYiT's Avatar
DIYiT
For the most part, yes. The window motors, trim panels, etc may take a little tweaking or new holes drilled, but for 99% of the piece, all of the doors are identical from 80-96/97.
Old Mar 31, 2014 | 05:07 PM
craftsmangary
The 97 is one piece glass that will barely fit in the door vs the 86 was two pieces. I know that it involved some cutting and welding, I'm thinking the inside door handle area is completely different, but it worked out nice.
bobs 80 f250
Nov 28, 2016 07:35 PM
JackErnie
Mar 31, 2014 01:24 PM
champlainl
Feb 23, 2014 12:04 PM
crazyredneckanyhow
WTB - Parts & other
Nov 9, 2012 09:21 PM
Cavstoy
Feb 21, 2012 09:56 AM
