Metal Carnage - Differential
Old Mar 30, 2014 | 12:50 PM
sammie0126's Avatar
sammie0126
While diagnosing an issue with my ebrakes I found the drivers rear axle seal was leaking coating the ebrakes in gear oil, replaced the seal. Decided to pull the differential fill plug and check to make sure it was full - drained a good bit out pulling the hub to replace the seal. To my horror this is what I find when I pull the plug. First photo is as it came out on the magnet - second is after a clean up. What is it? Any ideas? I am almost afraid to drop the cover....
Old Mar 30, 2014 | 01:09 PM
Tom's Avatar
Tom
Wuh oh, that doesn't look good. Almost looks like it got munched up in the gears, and that doesn't normally happen without doing damage. Is your rear end making any unusual noise?
Old Mar 30, 2014 | 01:11 PM
sammie0126's Avatar
sammie0126
Yep. Noticed a "whiring sound" this week, parked it - but honestly thought I had a door seal loose. Didn't sound like a whine more like a wind noise, went to dig into my ebrake issue and stumbled across this - puts the "whirring wind noise" in an entirely new perspective. I know I need to drop the cover at this point...just wondered if anyone who knows gear could tell by the pictures what metal part that was?
Old Mar 30, 2014 | 01:14 PM
kornfanjoe's Avatar
kornfanjoe
you have some bad luck at times... thats horrible. it looks kinda like part of a bearing race but until you pull the cover you cant be certain. either way that wont be the last of the debris floating around causing chaos in there.
bearing failure could ruin the axle seal and cause your original problem.
Old Mar 30, 2014 | 01:22 PM
Tom's Avatar
Tom
Yeah, that's my best guess at this point. Seems like, at least on semi-floating axles, the number one cause of seal failure is a bearing going bad. I remember she replaced those about a year ago, right? Perhaps it was a defective part or something got buggered up on the install.
Do NOT drive it until you take the cover off or more damage could result. Look on the bright side Christina, I'm sure your gears don't look as bad as mine did last November!
EXv10's Avatar
EXv10
It's hard to say exactly what it is since it went through the wringer at one time but it's not teeth and it's probably remnants left from a former rear end catastrophe. They would have stayed on the bottom even without the magnet. I wouldn't worry about it. Rear ends make a whine/howl sound when there is a tooth problem and a constant grumbling sound with a bearing problem. It could even be from a former wheel bearing part.
Old Mar 30, 2014 | 01:36 PM
sammie0126's Avatar
sammie0126
Ok I sure hope my gears don't look like that! But I know I need to pull the cover and it's not moving until I do, might as well get it over with. My garage already smells like "***" from pulling the hub and fixing the axle seal, nothing smells worse than nasty gear oil. I will dig out the tyvek and breaking bad gloves in a bit and drop the cover. Good thing the F150 is running good. Post up some pics once I get the cover off.
Old Mar 30, 2014 | 01:51 PM
kornfanjoe's Avatar
kornfanjoe
i hate the smell of old gear oil, and i deal with it all the time hopefully it didnt cause too much damage.
Old Mar 30, 2014 | 01:59 PM
snakedoc's Avatar
snakedoc
looks like a shim.
pull the drive shaft and see if the pinion moves.
if had to say you better bet on spending $200 up to fix it. as you will need new bearings, shims, seals. if it is not be run long the gears may be fine, it takes a lot to trash them with out them making a ton of noise.
EXv10's Avatar
EXv10
Yours doesn't even have one tooth missing. When and if you remove the cover take some pics of both sides of any more debris including those 2 pieces on both sides so we can identify it.
Old Mar 30, 2014 | 02:03 PM
EXv10's Avatar
EXv10
Originally Posted by snakedoc
looks like a shim.
That's why I don't think it is from this current rear end. Shims aren't in harms way and it's not a tooth so at this point I would say it it a part of a previous bearing cage.
Old Mar 30, 2014 | 02:08 PM
snakedoc's Avatar
snakedoc
i have seen a pinion shim get spit out, we put a new shim and crush sleeve in and it is been good, so it might be from the rear?
Old Mar 30, 2014 | 02:10 PM
sammie0126's Avatar
sammie0126
It's draining...
Old Mar 30, 2014 | 02:13 PM
Jmatthews's Avatar
Jmatthews
is a BAAAD MAN
Originally Posted by sammie0126
It's draining...
I can smell it from here
EXv10's Avatar
EXv10
That's extremely rare and the pinion bearing must have locked up and spun for that to happen.
