Sponsored by: Real Truck
Oil drain plug leaking
Old Mar 31, 2014 | 02:14 PM
EXv10's Avatar
EXv10
As much as I hate the Fumotos it's your only option. Just put some heavy sealer on it and install one time.
Old Mar 31, 2014 | 03:08 PM
clem1226's Avatar
clem1226
Originally Posted by MisterCMK
Remove your oil fill cap and put a shop-vac over the fill tube. Turn the vacuum on and then remove the drain plug. You will hear all kinds of gurgling noises but the oil will not drain out. You also won't suck any oil into the vacuum cleaner. Works like a champ! Nope, you will still spill a little bit that way.
I was wondering if that would work. On a 7.3 I imagine it would help if you also plugged the CCV vent.
Old Mar 31, 2014 | 04:20 PM
greg_8507's Avatar
greg_8507
I like it.
Old Mar 31, 2014 | 05:22 PM
MisterCMK's Avatar
MisterCMK
It shouldn't make a difference
Sent from my Telegraph using IB AutoGroup
Old Mar 31, 2014 | 08:31 PM
Greenlawnracing's Avatar
Greenlawnracing
Still a little lost on this one. I get that the Fumoto makes oil changes easier...but how does it address a leak?
Old Mar 31, 2014 | 08:45 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
Because you permanently seal it when you install it, and it never has to be removed again. Not just a crush washer or a felt gasket, but put RTV on the last bit of threads before it's tightened down and insta-presto no more leak. In your case it has nothing to do with making oil changes easier, and everything to do with permanently installing something that doesn't leak into the hole that is leaking.
Old Mar 31, 2014 | 08:50 PM
EXv10's Avatar
EXv10
^right^ The thing I don't like about them is it takes me 1 minute+- every 6+- months to remove my plug and I never drop it but it takes 5+- minutes more to drain with the levered plug, so you can't pay me to use one. If I ruined my threads by over tightening I would gladly use one. Those plugs don't need to be tight at all, I just give mine a little push on the wrench and that's it.
Old Mar 31, 2014 | 09:39 PM
pappy19's Avatar
pappy19
If you open up the oil filler it doesn't take that long to dump the oil using a Fumoto. I have them on all 3 of my rigs and it's a no-brainer for me. The more you un-screw a plug over time, the more chance it will leak. Once you add the Fumoto, no more leaks, turn the lever and ler her drain. Plus, I don't have to worry about where I put the plug or it falling into the depths of spiderhood 100 feet from where I'm working. Suit yourself.
Old Mar 31, 2014 | 09:43 PM
greg_8507's Avatar
greg_8507
My concern would be that one in a million chance something hits it and brakes it off. Cause it would most likely happen on the interstate 6 hours away from home, or out in the woods somewhere.
Old Mar 31, 2014 | 09:48 PM
pappy19's Avatar
pappy19
I have heard alot of folks worry about that but never heard of it happening. Maybe it has, but it must be one in a million. Even if it was hit on a rock doing brodies, it would probably just bend and not break. But again, I haven't seen or heard of one doing that in all the years I've used one; never seen one on this site confirmed. So carry your plug in your tool box just in case.
Old Mar 31, 2014 | 10:11 PM
Greenlawnracing
Ok makes sense now. Fumoto it is I guess. Am I safe to assume I have a cross threaded thread that caused this? I did look today and I can just BARELY feel/see some residue seeping from the washer. Barely.
Same - not that I ever go off road but it does seem to be somewhat of a hazard the one time you have to clear a ditch, etc. There is a small dent in my oil pan - no idea how it got there - but obviously something that tall has been under my truck.
Old Apr 1, 2014 | 12:50 AM
EXv10's Avatar
EXv10
Spiderhood? It stays in my hand and I set it down. I have had over 50 vehicles and never had a leaking plug but that's because I don't overtighten them.
Old Apr 1, 2014 | 12:53 AM
  #28
EXv10's Avatar
EXv10
Maybe something from spiderhood.
tnfordblue
Escape & Escape Hybrid
Jan 5, 2019 05:37 PM
Greenlawnracing
Apr 24, 2013 07:22 PM
macguy
6.7L Power Stroke Diesel
Aug 8, 2012 06:18 AM
DaveWW00
Oil & Lubrication
Aug 2, 2005 02:14 AM
jimb_1
Jul 19, 2000 01:19 PM
