heres a update on my help thread
Old Mar 28, 2014 | 10:39 PM
BIG ATS's Avatar
BIG ATS
as u recall i was have a charging system problem well guess what all along it was a bad alt every one was bench testing my alt at high rpm but not at low so it wasnt charging at idle but at high rpm yes so im passing that info on i do have a another problem i was driving it then it died on me i towed to mechic he couldnt find out why he tested the system found poss hpop was bad unplugged the icp i towed it home plugged it in for couple of days though to go out and see if its starts and she did start back up i went out and brought a scan gauge II here is my reading volts 13.9 w lights on ipr 22.61 icp 641 idle fmp 48.0 what is the normal reading for icp good one when i step on gas pedal brought rpm up to about 3000 i got a reasding of 1645 i cant find any info on it please help
Old Mar 28, 2014 | 10:48 PM
04badford's Avatar
04badford
ICP Values
koeo=0 low=625.5 high=1400-1450 operating value=0-4045
ICPV
koeo=0.2 lo=1.0 high=1.8 operating value=0.15-4.7
do the test on warm engine in park no HVAC on
Old Mar 28, 2014 | 10:56 PM
BIG ATS's Avatar
BIG ATS
help
Originally Posted by 04badford
ICP Values
ICPV
what does koeo mean so ur telling me my icp is good at 641 and high rpm
Old Mar 28, 2014 | 11:03 PM
04badford's Avatar
04badford
koeo key on engine off ,only at low Idle, should be at 1400+ at high 2500 RPM
Old Mar 28, 2014 | 11:04 PM
04badford's Avatar
04badford
yes ICP looks good hows IPR at the same test?
BIG ATS's Avatar
BIG ATS
help
ok thats what i got at high idle pass 1400
Old Mar 28, 2014 | 11:07 PM
04badford's Avatar
04badford
2500 rpm or steady don't for get the ICPV volts for ICP and IPR , is the truck surging and then stalls out?
Old Mar 28, 2014 | 11:19 PM
BIG ATS's Avatar
BIG ATS
help
ipr 22.61 reading
Old Mar 28, 2014 | 11:26 PM
04badford's Avatar
04badford
is that low idle or high?
Old Mar 28, 2014 | 11:32 PM
BIG ATS's Avatar
BIG ATS
help
how do i get volts it did w old alt due to ficm low volts not charging but got it back up to 48.0
Old Mar 28, 2014 | 11:41 PM
04badford's Avatar
04badford
enter pids into scangauge ICPV ( Injector control pressure volts ) your FICM should not drop below 45 at all
Old Mar 29, 2014 | 12:00 PM
BLADE35's Avatar
BLADE35
Scott this the Guy I been helping with that ALT
Looks like 3 threads Going Now LOL
But hey we finally getting somewhere HAHAHA
Old Mar 29, 2014 | 04:01 PM
04badford's Avatar
04badford
I noticed that last night when cruseing thru all the Threads , Just gave him the ICP and ICPV Values sounds like hpop leak , your the man and sounds like you've already meet with him and the truck. great guy you are Benny take care
oldhard47
Mar 22, 2016 07:54 AM
andysam
Apr 29, 2014 08:21 PM
Franko72
22
Oct 5, 2012 01:45 AM
93XLT150
Feb 24, 2011 08:40 PM
maticuno
1983 - 2012 Ranger & B-Series
May 2, 2004 10:24 PM
