Hi guys. I have a new to me SD 250 with the V10. It has the upfitter
controls in it. Any info here on how they work or what to do with them?
My owners manual doesn't tell me much. Thanks for your help!
Just search for upfitter switches. there are endless possibilities of uses for these switches.
I am only using 1 as of right now. I use it to activate my strobes. If I added a light bar I would use an upfitter switch to control that.
Ford made it easy by adding these there is also pass through wires that go through the firewall already in case you are running power to outside your cab area.
