Looking for a Maryland law that states that propane bottles MUST be removed from the RV to have them filled. I searched and searches thru MD laws until my fingers ached but couldn't find anything.
My RV has two of those large 40 pounders in it and was wondering if I could drive the RV close enough for the hose to reach. Will the operator says it's against the law here in Maryland?
I'm getting on in years and pulling those suckers is getting a might tough!
Do ANY states allow for this?
It seems like most places fill by weight putting the bottle on a scale. I don't see it as a safety issue or a legal issue, but more of a "this is the way we do it issue" in terms of establishing a base for the price. Anyone else have a different perspective? I have been to propane safety classes, but that topic was never addressed.
Around here, when they even charge per gallon , they put it on a scales so as not to overfill bottle.
Here's the kicker on that. With the overfill protection devices on the bottles, in theory it should be impossible to overfill. That is why the OPDs came into existence.
I think they always put them on a scale. The question is whether they have to.
In the past tanks were filled by weight and the weight of the tank and valve are clearly stamped on each tank so the person who filled it knew exactly how much they were putting in. In the olden days they also opened the overfill valve just like they do in a motor home and when the vapor came out, they knew the tank was full. But - an operator who was asleep at the throttle could overfill the tank, so they mandated Overfill Protection Devices in the tanks to automatically shut off the fill at the 80% mark.
So the question is, now that the tanks are just like those in a motor home, do they still have to put them on a scale and why.
I find nothing in the Cal DMV manual about propane tank removal. Here, the attendant measures the gallonage by the fuel meter on the filler assembly to determine totals. No scales but I've never tried to have anyone fill without removing the tanks.
I'll have to try next time with them in place and see if they'll do it.
No laws like this exist in Washington State where I am located but you should give your local RV dealership a call. They will be able to give you an answer because they are required to abide by those laws.
