78 4spd
Old Mar 24, 2014 | 08:42 PM
ford_0004's Avatar
ford_0004
78 4spd
I've got a 78 f150 with a 4spd .
I was wondering how many had this option it came with a 300i6 looking
to take the 302 swap out for a 351 what would change with the clutch and pressure if anything?
Old Mar 24, 2014 | 09:06 PM
MeanGreen460's Avatar
MeanGreen460
Is your truck 2wd or 4x4 ? A 4spd 435 was the most common trans behind a 300 6.In 2wd trucks with 300 6 a 3spd 3 on the tree was most common .if your putting a 351w in all 302 parts should work
Old Mar 25, 2014 | 08:03 PM
ford_0004's Avatar
ford_0004
It's a 4x4 everything looks to be correct short of who ever swapped out the 300 left one of the 300 motor mount tower
Old Mar 26, 2014 | 05:03 AM
ford_0004's Avatar
ford_0004
It's 4wd . It doesn't look like anyone added anything. The 4sods a 435 tho.
Old Mar 26, 2014 | 09:31 AM
paredneck33's Avatar
paredneck33
Just so you know no 73-79 1/2 ton 4x4's came with a 302. Only the 2wd's had the 302. Also none of these trucks came with a 351w. 77-79 came with the 351m and 400's. Which externally look the same. To swap a 351m or 400 for the I6 you will need different motor mounts and towers, wire harness and bell housing. Also not sure what size clutch the 300 used, but the 351/400 used an 11" clutch. However with that said if I were doing this swap I would automatically replace the clutch with a new clutch kit.
Although I'm not much of a fan the I6, I personally wouldn't swap the two. The 300 is a great engine. And like anything else if you build it right it will make really good power and phenomenal torque. So to me there is no reason to do a swap in either direction. Oh yeah I should mention that the exhaust would need to be changed as well.
Old Mar 26, 2014 | 05:39 PM
ford_0004's Avatar
ford_0004
It was 300 6 but someone swapped it out for a 302 .
Old Mar 26, 2014 | 05:53 PM
paredneck33
Oh ok that explains that motor mount towers then. That engine can't possibly sit right in there. Since Ford never put the 302 in the 70's 4x4's. And the eighties trucks motor mount towers won't work. Can we see some pics.?
SCFlareside
Apr 23, 2015 12:00 PM
sunspark
Jul 26, 2012 10:35 AM
dw_wanno
Engine Swaps
May 23, 2008 10:23 PM
Dirigo
Engine Swaps
May 17, 2007 04:08 PM
imca09
19
Jul 20, 2000 11:41 PM
