Clear or Tinted Glass/Ford script
Old Mar 24, 2014 | 08:17 AM
awjjim's Avatar
awjjim
My 1949 F4 226 restoration project is ready for glass. This has been a total frame off restoration but with a few updates that were added by original owner (turn signals and marker lights) and some of mine (6v-12v conversion, upholstery instead of hardboard) so I am open to subtle change. I know a lot boils down to personal preference; however input will be appreciated. Should all glass be clear or all tinted, windshield only tinted and rest clear? What about, Ford script etching?
Old Mar 24, 2014 | 08:59 AM
52 Merc's Avatar
52 Merc
Originally, all the glass was clear. Having the glass made with standard automotive tint will not be dark enough to look out of place and cut back on some of the suns heat and uv rays. Even if you did just the windshield tinted and the rest of the glass clear for a more stock look, it will help with glare while driving. Darker tint can be used if you want a more custom look. Adding the Ford script, or "bug" as it's known in the glass business, can be expensive and you really have to want it or are building a points-type show truck to justify the expense.
Old Mar 24, 2014 | 02:05 PM
tinman52's Avatar
tinman52
Welder User
I agree with Wayne. I used the green tint and really like it. It's not noticeable unless you are really looking.
Old Mar 24, 2014 | 02:27 PM
awjjim's Avatar
awjjim
Thanks, this confirms the configuration I was leaning towards. Tint on the windshield, clear for the rest. The "bugs" are not necessary, I am not after points just a good looking, fun truck.
Old Mar 24, 2014 | 06:34 PM
abe's Avatar
abe
Why not get the rear glass tinted?
In 53 tinted glass was an option. I think Ford called it Easy Eye Glass. Was it not an option for 48-52?
Old Mar 24, 2014 | 06:44 PM
38 coupe's Avatar
38 coupe
You can add the "bugs" to the glass your self: Roy Nacewicz Enterprises Ltd - Ford Bolts
Old Mar 25, 2014 | 01:10 AM
Moe Craig's Avatar
Moe Craig
Have you tried this your self?
Old Mar 25, 2014 | 06:45 PM
38 coupe's Avatar
38 coupe
I have not. Other local car club members have used his glass bug kits with good results. I think one of the tricks is you learn on the old glass you are removing before doing the new glass.
Old Mar 25, 2014 | 07:09 PM
FortyNiner's Avatar
FortyNiner
Thanks for the link - was looking for a way to cover up after my feats of strength test with my back window.
DW
Old Mar 25, 2014 | 07:13 PM
delawarebill's Avatar
delawarebill
Windshield tint ?
don't u think u should find out from dmv before u tint the windshield..
my state will fail u in a NY minutes.
Scotty's 52 F3
15
Jan 15, 2016 09:32 PM
davewave649
May 30, 2011 11:54 PM
cts1954
Dec 7, 2009 09:14 AM
vintage tin
13
Sep 9, 2009 02:04 PM
Walston
Mar 5, 2006 12:53 PM
