5.8 ford 250
Old Mar 21, 2014 | 10:32 PM
Grayghost8295's Avatar
Grayghost8295
5.8 ford 250
I have a 95 f250 5.8 automatic truck that has an awful misfire, will run but sounds like crap. Has great compression and spark, but 2 and 3 injectors will not pulsate....has power to both sides of wires on injectors, but will not pulsate even tho 1 and 4 are pulsating, I have swapped injectors and same thing. Any ideas?? Thx
Old Mar 22, 2014 | 01:49 PM
Conanski's Avatar
Conanski
On this truck the injectors are fired in batches of four, 1, 4, 5, 8 are together and 2, 3, 6, 7 are together. Sounds like you have a chewed wire somewhere or maybe the pin in the PCM connector is pushed back.. pin 59 for the second batch. If you disconnect the PCM you can test for continuity from there to all injectors, if that checks out your problem is inside the PCM.
Old Mar 24, 2014 | 05:39 PM
Grayghost8295
Thanks for the advice! I'll check it out
c4jlca
Jan 13, 2013 03:32 PM
eatont9999
May 8, 2012 09:20 AM
lovs2fly
Feb 21, 2012 09:57 PM
roadrage
1983 - 2012 Ranger & B-Series
Jun 30, 2005 09:57 AM
