hydro locked
Old Mar 21, 2014 | 09:49 PM
Jerry Chaney's Avatar
Jerry Chaney
hydro locked
So I'm getting off the interstate, truck is running great. Until I stop at the light. All of a sudden thick white exhaust coming out of pipes, enveloping surrounding vehicles, and motor starting to run rough. Light turns green and I pull out in front of oncoming cars to quickly turn into 7-11 parking lot turn motor off and yell out...****.
I check under hood, under truck, check oil. everything looks good. try to start motor and nothing. To me, it sounded like motor seized up. I called a mech. he thought it was bad oring on injector and hydro locked. My question is, can I just take out glow plugs and then try and start again? I googled Hydro locked motors and did not like what I saw. Connecting rods bent or broke. Or do I need new motor?
Old Mar 22, 2014 | 12:29 AM
bulla's Avatar
bulla
Sorry you feel that way.
Old Mar 22, 2014 | 12:35 AM
bulla's Avatar
bulla
sorry you feel that way.
Old Mar 22, 2014 | 07:41 AM
F350-6's Avatar
F350-6
If it was really hydrolocked, I'd turn the motor by hand after pulling the glowplugs. The starter will just make a mess of the fluid in there by spraying it out too fast.
Old Mar 22, 2014 | 08:14 AM
Pikachu's Avatar
Pikachu
Did you get a good whiff of the smoke? Did it smell like fuel, or did it smell like coolant?
Old Mar 22, 2014 | 09:29 AM
Jerry Chaney
Yep, it was fuel. Going over to where my truck was towed yesterday. Pull VC and glow plugs. Wish me luck!
Old Mar 22, 2014 | 10:03 AM
Pikachu's Avatar
Pikachu
Sounds like the logical next step to me. If you can have someone turn it over by hand while you watch, that would probably be the best way to do it. It will still make a mess if there's liquid in the cylinder; I managed to shoot oil about 6 feet even turning it by hand.
Old Mar 22, 2014 | 10:36 PM
HD Rider's Avatar
HD Rider
The cylinder that's full of fuel has a bad injector. Your engine should be fine.
Old Mar 22, 2014 | 11:34 PM
bulla's Avatar
bulla
Old Mar 23, 2014 | 10:33 AM
HKusp's Avatar
HKusp
Damn Jerry, you and Rich have found a lot of interesting ways to have to pull the valve covers, haven't you!
Old Mar 23, 2014 | 10:41 AM
Jerry Chaney
Ha..what do I know! It was coolant in cylinders, #2 and #8. So then I'm told that my cups are cracked. Took them out and inspected them closely. I could not see anything. Putting new ones in today, as soon as it warms up (colorado).
Oh and one more thing. At the risk of coming off as an Idiot, removing #2 injector revealed that I had missing brass washer. Opps, that was my bad. New O rings were put on by me, couple of months ago. And that first O ring on injector was spilt. Got new O rings for the two Injectors. This time from ford. Going to use marine grease. Im hoping that new brass washer is going to quiet down my motor finally.
Old Mar 23, 2014 | 10:50 AM
HKusp's Avatar
HKusp
Who's were the other o-rings, Dormans?
Old Mar 23, 2014 | 11:26 AM
bulla's Avatar
bulla
Old Mar 23, 2014 | 11:28 AM
bulla's Avatar
bulla
Old Mar 23, 2014 | 12:44 PM
Dan V's Avatar
Dan V
I have to say...all of you...ALL OF YOU, that have gone under the VC's multiple times have my highest respect. I think that if I would have to do some of these things that many times I'd light it on fire and walk away. My legs and calves still hurt 2-3 days after.
