Sponsored by: Real Truck
Rust on 2011 F350
Old Mar 18, 2014 | 05:57 PM
Fastbird's Avatar
Fastbird
Rust on 2011 F350
I notice little rust on rear fender behind right rear wheel above tail pipe when I was washing truck today.I do have 52K miles on truck.
Anybody have rust problem,how long is warranty on rust?
Thank you.
Old Mar 18, 2014 | 06:15 PM
Snowseeker's Avatar
Snowseeker
All fords have rust, ford won't warranty it unless it is a hole by that time you will be out of warranty.
Old Mar 18, 2014 | 07:37 PM
sammy77's Avatar
sammy77
Thank you.
Already? . Did you buy the truck new? Do you know if that area was previously repaired? Post a pic if you can.
Old Mar 18, 2014 | 07:39 PM
fordman19762003's Avatar
fordman19762003
was this caused by rock chips that went unrepaired? If so Ford won't honor the corrosion warranty. Like Snowseeker said the corrosion warranty only cover complete rust through and I believe it has to be within 5yrs or 100k.
Old Mar 18, 2014 | 08:41 PM
Kdr358's Avatar
Kdr358
After my trucks first winter I have a nice coating of surface rust on all the un-painted parts. I plan
on cleaning it as best I can and coating everything with fluid film to try to fight the rust.
Old Mar 19, 2014 | 05:56 AM
Fastbird's Avatar
Fastbird
I bough it used 2 years ago.I can't post pictures.
Old Mar 19, 2014 | 06:04 AM
Fastbird's Avatar
Fastbird
I don't think so.It is about 1"x3" area where paint is pealing because of rust underneath.
My 99 F250 didn't have this much rust when I sold it in 2012.
Old Mar 19, 2014 | 07:05 AM
senix's Avatar
senix
Since it is so new (the truck) I would invest in a repair and repainting of the spot.
Old Mar 19, 2014 | 08:15 AM
Snowseeker's Avatar
Snowseeker
The funny part about that is ford has it figured out that even if the sheet metal wasn't painted at all it would still take 5-6 years to rot threw, coincidentally just outside of their "warranty period".
Instead of investing the time and money to prevent the problem and increase the quality of their product they invest the money into the research of "How long can we warranty this thing without actually paying for anything under warranty?" The next department is paid to make the part as cheap as possible to hold up good enough for that short period.
Old Mar 19, 2014 | 09:30 AM
xmontex4's Avatar
xmontex4
I would get it fixed like previously stated since it's so new. What part of the country are you from? If its anywhere in the rust belt get it fixed then coat the backside while its still fresh. I fixed my bed after it rotted through twice (first time was a bad repair). Personally pull the bed and POR, topcoat, fluid film the whole underside to make her last a long time. It's a few hundred bucks upfront and a decent amount of time but it saves a hell of a lot more time (can be a month+ if its bad) and money (thousands) later on when it gets bad.
Old Mar 19, 2014 | 12:14 PM
meborder's Avatar
meborder
could spray some calcium chloride on the affected spot.
should speed the process up so that it perforates within the warranty period.
Old Mar 19, 2014 | 12:58 PM
2ndStroke's Avatar
2ndStroke
No mud flaps?
Old Mar 19, 2014 | 01:36 PM
sammy77's Avatar
sammy77
Mud flaps are not cool.. and they are illegal here in IL.
Old Mar 19, 2014 | 01:46 PM
2ndStroke's Avatar
2ndStroke
No they aren't cool, but my truck has no rust behind the wheels
If I didn't with the amount of gravel roads I drive on, I'm sure I would by now.
Old Mar 19, 2014 | 01:48 PM
sammy77's Avatar
sammy77
What are you doing driving on gravel..? There's still plenty of snow up there..
